1. sschimel's Avatar
    I just got my S7Edge and put music on a microSD card. I dragged the files onto the card in the correct order but when I open a music player to play them, the files are all mixed up. And even when I downloaded directly onto the card in the phone, the files aren't in the correct order. How can I get the files on the card to appear in the right order? For instance, I have several complete operas on the card. And instead of keeping all of the files for the operas, such as Act 1, Act 2, etc, all of the operas get jumbled.
    08-05-2016 01:04 PM
  2. B. Diddy's Avatar
    Are you using the stock Music app? Are the files playing in alphabetical order? Do you know if the music files have the correct ID3 tags associated with them?
    One solution is to use a folder-based music player like PowerAmp or MortPlayer Music, and organize your files in the appropriate Artist>Album>Song folder hierarchy.
    thecomicbookandme and fsfty like this.
    08-05-2016 03:06 PM
  3. xNinjasapp's Avatar
    If you need a good ID3 editor on Android, you should try Music Doctor. It can scan your SD card and you can browse by folder then add to the tags as you see fit. You can also search for songs without tags and fix those too.
    Good luck!
    https://play.google.com/store/apps/d...as.musicdoctor
    09-16-2016 10:12 AM
  1. In depth video review of the Note 7
    By ajb1965 in forum Samsung Galaxy Note 7
    Last Post: 08-07-2016, 12:49 PM
  2. Iris Scanner works in darkness (VIDEO)
    By smooth4lyfe in forum Samsung Galaxy Note 7
    Last Post: 08-06-2016, 09:40 PM
  3. Mass rename of local photos in Google Photos
    By Cyber Akuma in forum Ask a Question
    Last Post: 08-06-2016, 12:23 PM
  4. Replies: 2
    Last Post: 08-05-2016, 03:58 PM
  5. Change the Color Font I see while creating a Text Message ??
    Last Post: 08-05-2016, 01:02 PM
