Hey guys, New to Android and gotta say Im LOVING it so far but starting to hit a annoying problem the last week or so
In multiple apps (Whatsapp/Facebook/Messenger etc) Im running into a problem where after a while the Enter key wont work after I type text, Basically I need to back out and go back into the post or message so the keyboard is not up on screen and only the Arrow key is showing before it will accept the enter and post the text.
I was using Samsung Keyboard and read up about trying to clear cache/data and that seems to work for a little while but I also sometimes need to do a soft reset (Power/Down volume button) and kill it before it becomes responsive to accept the enter key again.
I also tried downloading SwiftKey and that worked for a while but now its also doing tsame thing so that rules out a Keyboard application and points more to the OS/Bug
I got a Samsung update about 3-4 weeks ago but this has only just started in the last week or so, There has been no apps ive downloaded in the last week either that could be causing it
any suggestions ideas what may be causing it or how I can fix so i dont have to do a reset once or twice a day so I can use the thing !?!?
