1. Christine Aflak's Avatar
    Hi there! After seeing the differences between the Note 7 and S7 Edge, I've decided my next phone will be the Edge.
    My question is regarding the phones on kogan. They are almost dirt cheap (at least in Australian dollars), but what I want to know is which variant they are and if they will receive the same updates as carrier versions?
    I don't wanna save a few dollars but get stuck with old software. The updates are very important to me.
    JHStewart1023 likes this.
    08-06-2016 12:56 AM
  2. Christine Aflak's Avatar
    Anybody have any experience with Kogan?
    08-08-2016 12:50 PM
  3. Christine Aflak's Avatar
    Update-wise anyway...
    08-08-2016 12:51 PM
  4. stylic_au's Avatar
    I bought a factory unlocked S7 Edge on ebay from Honk Kong and everything has been great. No bloatware preinstalled. The updates depend on where is the device from. If you contact the seller or Samsung they should be able to tell you the country of origin. I doubt there is much difference because it will be most likely from Taiwan or China and the update frequency should be good.
    08-09-2016 01:38 AM
  1. Edge turning off, very unstable
    By Toby01 in forum Samsung Galaxy Note Edge
    Last Post: 08-09-2016, 01:28 PM
  2. problem with lock screen in s7
    Last Post: 08-06-2016, 03:26 AM
  3. Replies: 0
    Last Post: 08-05-2016, 11:33 PM
  4. Replies: 1
    Last Post: 08-05-2016, 07:13 PM
  5. Screen protector and case suggestions for S7?
    By valeriolucciola in forum Samsung Galaxy S7
    Last Post: 08-05-2016, 06:48 PM
