1. Guyguy360's Avatar
    So just like i asked,i did a total of about 12 factory reset since i bought this phone on march,the last factory reset was about 1 week ago, now i have so much bad gaming experience,gaming has never been that bad before the last factory reset,now all games are so much laggy almost unplayable, i tried to reboot the device several times but it doesn't help, so did i damage something by doing that much of factory reseting? I remember that at some point i had to reset twice a day.
    08-06-2016 09:08 AM
  2. Tim1954's Avatar
    Why do you reset so often?
    08-06-2016 09:19 AM
  3. fsfty's Avatar
    This is the first phone I haven't had to do a reset on cause it's so trouble free. I can't imagine how multiple resets would harm the phone though.
    08-06-2016 09:37 AM
  4. Guyguy360's Avatar
    i usually reset after each system software update and the extra resets were due to some bugs and glitches that i face from time to time
    08-06-2016 09:38 AM
  5. Guyguy360's Avatar
    i can't blame my phone for this it's all on me, iam not a regular user, i like to mess around with my phone and that always leads to reset to fix what i have done , plus i reset after each system update, so u think factory reset is harmless/not bad for internal hardware??
    08-06-2016 09:45 AM
  6. Guyguy360's Avatar
    Should i flash my device??
    08-06-2016 10:52 AM
  7. yohannrjm's Avatar
    I've reset phones a lot in the past, and had no issues. I'm not an expert, but I can't imagine how resetting would harm the phone. I guess there's a chance that something would go wrong with the resetting process and you'd softbrick the phone, but I've not heard of that happening from a regular factory reset.
    08-06-2016 03:22 PM
  8. Guyguy360's Avatar
    Thank u for ur reply, well the only issue i feel right now is laggier games,could it be soft brick?? Not to mention that the last reset was immediately after the latest firmware update (60mb)
    08-06-2016 03:55 PM
  9. yohannrjm's Avatar
    Nope, it's not a softbrick if games lag. I'm not sure why some games lag after updates, but I've had that happen too. Usually, a reset makes things smoother for a while, but it would depend on the game.
    After major updates, a factory reset is usually regarded as a good thing. However, there are always a few reports of post-reset issues. I'm not sure why that is.
    Guyguy360 likes this.
    08-06-2016 03:59 PM
  10. Guyguy360's Avatar
    Thank u so much
    08-06-2016 04:05 PM
  1. Why my 50℅ of RAM occupied even no application is running
    Last Post: 08-07-2016, 11:56 PM
  2. Replies: 2
    Last Post: 08-07-2016, 03:36 AM
  3. I am able to wipe factory settings in recovery mode.
    Last Post: 08-07-2016, 01:23 AM
  4. galaxy s6 charging port is loose, phone is not charging.
    Last Post: 08-06-2016, 08:28 AM
  5. Replies: 0
    Last Post: 08-06-2016, 12:40 AM
