1. Doc X's Avatar
    R the other launchers running in the background? I'm using a SG S7EDGE
    08-08-2016 07:01 PM
  2. koves's Avatar
    I wouldn't think so ... But I'm not a 100% sure
    08-08-2016 07:10 PM
  3. BluBrett's Avatar
    If you're constantly switching between launchers, yes it may. If you haven't used 2 of the 3 in a day or two, the device should have ended them by that point.
    08-08-2016 08:17 PM
  1. Is the Galaxy Note 10.1 (2014) Out of Luck for Marshmallow?
    By DennisOS2 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-10-2017, 12:02 AM
  2. Replies: 1
    Last Post: 08-08-2016, 08:36 PM
  3. Replies: 1
    Last Post: 08-08-2016, 06:37 PM
  4. Replies: 0
    Last Post: 08-08-2016, 06:17 PM
  5. Replies: 0
    Last Post: 08-08-2016, 06:08 PM
