1. Antony Guan's Avatar
    This feature came out of no where, I never enabled it but once I launched Buzzfeed for the first time on the phone then this started happening but I don't think it's the apps fault since I have uninstalled it. Instead of using the fingerprint sensor like always to unlock, I get this message "Enter pattern instead of fingerprint recognition because of security policy". I've tried to find a solution to this but everything I looks to be talking about the double tap to lock gesture on nova launcher but I never used that gesture also they talked about an update that was around April too. I looked into device admins in the settings, there was a nova launcher permission to lock the screen and I turned that off but that message stilled popped up saying I needed to enter my pattern instead sometimes. This occurs mostly when I'm in an app and when the screen is turned off, after a certain time period that message will pop up which is very annoying. So how do I fix this issue I feel like factory reset wouldn't fix it and feel like it's a software issue but is there a solution to fix this annoying problem?
    08-08-2016 08:39 PM
  2. chanchan05's Avatar
    That screen usually pops up when you have an app controlling when the phone screen is turned off an locked. Do you have any app that does that? Maybe a power saver app?
    08-08-2016 09:26 PM
  3. Antony Guan's Avatar
    I don't think so, but where could I find out what app is doing this?
    08-09-2016 01:40 PM
  4. Antony Guan's Avatar
    wait, the screen lights up for no reason, so something is happening to force me to enter the pattern
    08-09-2016 03:38 PM
  5. Antony Guan's Avatar
    wait now my screen lights up for notifications wtf that never happens
    08-09-2016 08:23 PM
  6. chanchan05's Avatar
    Is there an app that has a setting to unlock the phone on notification? There are some apps with that setting. It may also cause than due to security concerns.
    08-09-2016 09:52 PM
  7. Antony Guan's Avatar
    There is probably but I can't seem to find it
    08-10-2016 02:25 PM
  8. Antony Guan's Avatar
    I checked in the device admins, disables the ones that says to lock my phone but that pop up keeps coming up still
    08-11-2016 01:11 AM
  9. Antony Guan's Avatar
    Fixed it, it was something to do with light flow it was in the other security settings
    08-12-2016 01:53 AM
  1. Replies: 1
    Last Post: 08-08-2016, 10:53 PM
  2. Which screen-off setting am I seeing?
    By BluBrett in forum Samsung Galaxy S7 edge
    Last Post: 08-08-2016, 10:28 PM
  3. Why is my Samsung Galaxy S6 not turning on?
    Last Post: 08-08-2016, 10:02 PM
  4. Replies: 0
    Last Post: 08-08-2016, 07:12 PM
  5. Replies: 0
    Last Post: 08-08-2016, 06:46 PM
