1. Mostafa kamal Romel_1988's Avatar
    Hi i am using Spigen neo hybrid cse in Galaxy S7 Edge. It doesn't fit with any tempered glass screen protector and plastic screen protector. Even it peel off spigen curved crystal HD screen protector. Can you advise me some good tempered glass screen protector which could fit with spigen neo hybrid case?
    08-09-2016 01:12 AM
  2. victoryrules8's Avatar
    I don't really think there are any full coverage glass screen protectors worth while out there. However patchworks makes a good screen protector that doesn't cover the edges that may work for you. You could check that one out. I haven't tried it personally but I do have a friend who has it on his and he seems to like it.
    08-09-2016 05:19 AM
  3. qbngator's Avatar
    Spigen Crystal HD screen protector is awesome. Found it for $9 on Amazon (retails for $25). Easy application, no peeling or bubbling.
    08-09-2016 05:54 AM
  4. jazz70's Avatar
    I use a neo hybrid also and wanted to use a tempered glass protector but with the overall poor reviews of tempered glass protectors for the s7e and the problems with keeping one on with a case it has been difficult to find anything that works.
    This forum has some long threads on this subject and may have some helpful info
    08-09-2016 10:30 AM
  1. Replies: 1
    Last Post: 01-16-2017, 09:16 PM
  2. Replies: 1
    Last Post: 09-20-2016, 09:40 AM
  3. Samsung Galaxy S6 is only showing black screen and blue light
    Last Post: 08-08-2016, 11:51 PM
  4. How do I transfer photos from my Samsung Galaxy s6 to my PC?
    Last Post: 08-08-2016, 11:41 PM
  5. Replies: 0
    Last Post: 08-08-2016, 11:01 PM
