1. Who884l5's Avatar
    New to the forum here! *hi!*
    For a while after i downloaded gsam i was only using 5.5% an hour. Then i downloaded nova launcher and at 7.7% i was happy with the drain and the launcher. Went to work one day and noticed a massive drain. Cant figure out why android system is using so much google play is also a culprit.
    Downloaded battery doctor....it disabled some stuff in the background. It shot downto 8.8 for a 10 mins then shot back up
    *update*
    It was google hangouts demolishing my battery.
    08-09-2016 08:18 PM
  2. victoryrules8's Avatar
    Hi! Welcome!👍👍
    08-09-2016 08:34 PM
  3. kjung7's Avatar
    A screen shot of your battery usage would help
    08-09-2016 08:54 PM
  4. Who884l5's Avatar
    Okay, downloaded the app. Not only did i massivly mess up my username i accidently posted without finishing. Help massive battery drain or am i missing something?-1470794425834.jpgHelp massive battery drain or am i missing something?-1470794435313.jpg
    08-09-2016 09:00 PM
  5. Who884l5's Avatar
    Seems that google hangout was killing my battery big time for whatever reason. Help massive battery drain or am i missing something?-1470801625696.jpg
    08-09-2016 11:00 PM
  6. kjung7's Avatar
    Also disable all bloatware. I recommend an app called EZ Disabler
    Also Pokémon Go is a huge battery drainer at least from what I've heard
    08-09-2016 11:16 PM
  7. Who884l5's Avatar
    This is the first time iv seen ez disabler. Also im aware of pokemon go. However in this case it seems hangouts taking up an unessecary amount to battery.
    Thank you for this app. Maybe i can use it. To compisate for hangouts drain.
    08-09-2016 11:22 PM
  8. chanchan05's Avatar
    First thing I would do is get rid of Battery Doctor. Not only does it do nothing to help, it would increase battery usage in the long run.
    Pokemon Go is your huge battery drain. It calls on Android System for location, and Google Services for the updating of your profile minute by minute (distance walked, etc), hence the huge battery drain for both items.
    08-10-2016 04:31 AM
  9. Who884l5's Avatar
    In this instance pokemon go was off. I need to update the post but iv confirmed the issue to be google hangouts. After disableing it no longer goes up to 20% an hr. Its now 3.5 to 5.5.
    08-10-2016 08:27 AM
  1. I deleted android os and all roms!! PLEASE HELP!
    Last Post: 08-24-2016, 05:05 PM
  2. Replies: 6
    Last Post: 08-14-2016, 01:32 AM
  3. help with master reset
    By Debbieespo3333 in forum Ask a Question
    Last Post: 08-13-2016, 05:24 AM
  4. Replies: 1
    Last Post: 08-09-2016, 06:07 PM
  5. Replies: 0
    Last Post: 08-09-2016, 06:01 PM
