1. gmaister22's Avatar
    Hello guys
    i am considering purchasing a Sandisk Ultra 128GB SD Card for my S7 EDGE
    But, i read so many reports that people got fried cards from their Samsung Galaxy phones, and most of them were Sandisk, whats your recommendations?
    Also Sandisk Ultra is 80mbps read and 20mbps write, will that be enough for 4k vid? Or maybe i should get a Sandisk Extreme?
    08-10-2016 01:31 AM
  2. Javier P's Avatar
    Moved to the S7 edge forum for more visibility.
    08-10-2016 07:04 AM
  3. gmaister22's Avatar
    Anyone guys?
    I'm looking at the Samsung Evo+ 64 GB, Sandisk Extreme Pro 64GB and the Sandisk Extreme 64GB too, im not sure if the r/w speed matters a lot on the phone
    08-10-2016 04:11 PM
  4. asdf's Avatar
    The brand of the card won't make a difference.
    mlblack16 likes this.
    08-11-2016 02:17 AM
  5. mlblack16's Avatar
    My first Galaxy was the S3. Great phone, but it destroyed the first sd card then acted screwy with the 2nd one for the remainder of the time I had it. Two different brands of cards. I'm on my second S7 Edge because the first had terrible issues with the 64GB sd and it is SanDisk brand.
    08-11-2016 08:10 AM
  6. t11rmh's Avatar
    Brands which are not Samsung or SanDisk are more prone to issues. To be sure use a Samsung card.
    And the OP shouldn't believe everything he reads on the Internet about these phones frying cards. I have only ever had one issue with a card over the years and I replaced the SanDisk card with a Samsung one and problem solved.
    At the moment I have 3 SanDisk 200gb cards in my s7, s7e and tab s 10.4 with no problems. I have a SanDisk 128gb in my J5 with no problems.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    sicario666 likes this.
    08-11-2016 02:11 PM
  7. Wizzy's Avatar
    My SanDisk card got corrupted and I couldn't write to it. My Samsung card, on the other hand, has worked perfectly since I bought it.
    Posted via the Android Central App from my S7 edge
    08-11-2016 03:12 PM
  8. illdini's Avatar
    Sandisk cards work fine in the s7 edge (I'm using a 200 GB card now). Just make sure you buy from from a reputable vendor (*not* eBay, as there are many fakes) and regularly back up anything important to cloud and/or external disk.
    08-12-2016 10:59 AM
  9. gmaister22's Avatar
    I just ordered Samsung 128GB Pro Plus of amazon!
    08-19-2016 04:08 PM
  1. Replies: 2
    Last Post: 01-04-2017, 02:52 PM
  2. Samsung galaxy s5 neo - notifications in status bar only?
    By pawprints86 in forum General News & Discussion
    Last Post: 08-24-2016, 04:01 PM
  3. Why Skype is not connecting in Samsung J5?
    Last Post: 08-17-2016, 12:37 PM
  4. How can i mirror my lg g stylo to my Samsung smart tv
    Last Post: 08-10-2016, 12:58 AM
  5. Samsung Galaxy Tab A 10.1 & 2015 Tundra In Dash Mount
    By dano92580 in forum More Samsung Tablets
    Last Post: 08-10-2016, 12:29 AM
