1. John Morales's Avatar
    Wondering if anyone can help me out. My phone keeps losing the SD card installed. I've gone through 3 SD cards and one phone replacement and still have the same issue.
    If I download a movie or save a pic from a text message, then 7 out of 10 times I will be prompted to insert an SD card even though there is one in the phone! Every time this happens I need to pull out the SD card a couple of times before the phone registers that there is one, or put the SD card in my computer and click on 'repair errors' (sometimes this message won't pop up). Then I need to re-insert the card into the phone and re-create all my music playlists.
    Right now, my pics and music are showing up on the phone but when I go to a movie on my amazon movies app I get a message to insert an SD card to proceed.
    08-11-2016 11:09 AM
  2. Premium1's Avatar
    Maybe try putting the SD card into the phone and format it to see if that helps?
    If that doesn't work, check this thread out and see if the items they talk about work. http://forums.androidcentral.com/sam...rd-issues.html
    08-11-2016 11:44 AM
  1. Translucent lines appearing to galaxy s7 edge
    Last Post: 12-13-2016, 11:02 AM
  2. Both my SD card and SIM card aren't being detected
    By jws99 in forum Ask a Question
    Last Post: 08-11-2016, 10:55 AM
  3. Replies: 0
    Last Post: 08-11-2016, 10:33 AM
  4. Replies: 0
    Last Post: 08-11-2016, 10:20 AM
  5. microphone not working during calls
    Last Post: 08-11-2016, 10:13 AM
