1. Anthony langone's Avatar
    I'm trying to set different notification sounds for different things. For example I want my Facebook app notification, my What's app notification, and my text message to sound different. I'm kinda new to the Android operating system, switched from Windows if you'll belive it. Help is greatly appreciate.
    08-11-2016 01:03 PM
  2. sicario666's Avatar
    Have you tried going into each app? Normally you can change them within each app
    08-11-2016 01:05 PM
  3. Anthony langone's Avatar
    I have and after I change them the return to the default tone for some reason
    08-11-2016 01:22 PM
  4. chanchan05's Avatar
    Try using Lightflow
    08-11-2016 05:49 PM
  5. Anthony langone's Avatar
    Is that an app?
    08-11-2016 06:08 PM
  6. natefish's Avatar
    Yes
    08-11-2016 06:59 PM
  7. MikeRotch76's Avatar
    Try keeping your custom ringtones in internal memory instead of the SD card.
    08-12-2016 01:16 AM
  1. Replies: 1
    Last Post: 08-11-2016, 09:59 PM
  2. No sound from apps but sound from ringing.
    By Machote in forum Samsung Galaxy Note 3
    Last Post: 08-11-2016, 08:53 PM
  3. Can't get individual notifications for apps
    By Anthony langone in forum Samsung Galaxy S7 edge
    Last Post: 08-11-2016, 05:37 PM
  4. No text notification for 'some' senders
    By Tafflad in forum Samsung Galaxy S7
    Last Post: 08-11-2016, 12:00 PM
  5. Replies: 0
    Last Post: 08-11-2016, 11:24 AM
