1. MclBR's Avatar
    Hey, guys!
    I was wonder if the battery of my Galaxy S7 Edge (Version GM-9350F) with Exynios Processor is normal.
    I'm only getting 5 hours of Screen on Time. I've seen people on the forums getting around 6, 7 and even 8 hours of SoT.
    My usage is pretty average...
    The main apps used are WhatsApp, Spotify, Browsing and, sometimes, a short session of game (Castle TD and UFC mainly).
    Here are the shots:
    Is my battery deffective? 5 hours SOT Exynios-screenshot_20160812-230636.jpg
    Is my battery deffective? 5 hours SOT Exynios-screenshot_20160812-230641.jpg
    Is my battery deffective? 5 hours SOT Exynios-screenshot_20160812-230659.jpg
    PS.: This is my 4th charge circle.
    PS².: I've disabled autosync and wifi/bluetooth search location. Also, brighteness is set to around 40%.
    08-12-2016 09:26 PM
  2. D13H4RD2L1V3's Avatar
    Hello there!
    17 hours and 43 minutes of total uptime with nearly 5 hours of screen-on-time isn't too bad, but it could be better.
    Do you use mobile data often? Note that the other users with higher SOT numbers may have different usage patterns, and SOT is correlated with usage patterns, and you need to factor in overall device uptime and battery draw for a better picture.
    You mentioned that this is your 4th charge cycle. Is this device obtained recently? If so, it might take a while for it to be "run-in". It should stabilize soon.
    08-12-2016 10:13 PM
  3. Antony Guan's Avatar
    5 hours SOT is perfect I usually get 5-6 depending on what I use. Don't worry for now
    08-12-2016 11:28 PM
  4. t11rmh's Avatar
    Nothing wrong with those stats.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    08-13-2016 09:23 AM
  5. MclBR's Avatar
    Hello there!
    Hey! Yes, I bought it 3 days ago.
    When I'm not in home, I do use LTE. So, yea, I don't know...
    Thanks for your replies, guys. I just saw some people saying that they could get around 6,5 up to 7,5 hours in Screen on Time, and I got kind of scared, thinking that my phone could be deffective...
    So... nothing to worry about, right?
    Thanks!
    08-14-2016 08:36 AM
  6. D13H4RD2L1V3's Avatar
    Thanks!
    5 hours of SOT with 17 hours of use is not bad at all. In fact, it's actually pretty good. It could be better, but that's only when you play around with the settings to squeeze more runtime out of it, which in this case, isn't really needed.
    Note that SOT directly correlates with usage pattern. Some heavier users may get more SOT numbers, but as a consequence, may have shorter overall uptime.
    You have to take into consideration the usage pattern of an individual alongside the total uptime and SOT in order to get a better idea of how a phone performs battery-wise with that usage pattern.
    MclBR likes this.
    08-14-2016 09:17 AM
  7. Tech-Newb's Avatar
    I wish i can get those crazy SOT with my S6 edge
    My S6 edge can only handle 3 hours SOT and 15 hours up time before reaching 20% battery left.
    My sister's S7 edge can go up to 4 days with 4 hours SOT.
    Posted with ❤Love❤
    08-14-2016 09:22 AM
  1. Replies: 4
    Last Post: 08-17-2016, 09:57 PM
  2. My phone is stuck in a bootloop
    By Jose Gonzalez25 in forum LG V10
    Last Post: 08-15-2016, 11:07 AM
  3. How do I transfer my music from my iphone to my samsung s7
    Last Post: 08-12-2016, 10:04 PM
  4. Why does my phone say emergency calls only?
    Last Post: 08-12-2016, 09:11 PM
  5. Popup ads on my home screen
    By Bawseee in forum General Help and How To
