1. popkurn611's Avatar
    This happens quite frequently and I usually don't hit the 50% mark until 4pm.
    I'm on at&t BTW. Have barely used the phone today too.
    08-13-2016 12:58 PM
  2. thejammer's Avatar
    I'm in the same boat as you. Battery life sucks since June update
    Posted from my 7 Edge via the Android Central App
    08-13-2016 09:01 PM
  3. popkurn611's Avatar
    Glad to hear I'm not the only one! It got better for a few days on the July update but then tanked again
    08-13-2016 09:25 PM
  4. thejammer's Avatar
    Mine has been consistently bad
    08-14-2016 01:52 PM
  5. thejammer's Avatar
    My phone has also been extremely hot as well
    08-14-2016 01:53 PM
  6. popkurn611's Avatar
    Sucks!
    08-14-2016 07:28 PM
  7. jeetu4444's Avatar
    Try a hard reset...
    08-15-2016 07:14 PM
  8. Norbu Fnu's Avatar
    Try a hard reset...
    Telling people do hard reset or factory reset is easy but for some people doing reset is easy you could loose important documents, pictures, game profiles, music backing up all these 40gb files takes at least 2hours then after reset problem still exist this frustrates and pisses off most. So think twice before you tell people do reset
    10-17-2016 10:25 AM
  1. s7 edge vs s6 edge battery + heat
    By quiksetz in forum Samsung Galaxy S7 edge
    Last Post: 11-04-2016, 10:33 AM
  2. Conflicting Reviews? (Finger Print, Camera, and Battery Life)
    By hisense in forum Alcatel Idol 4 Series
    Last Post: 08-21-2016, 04:38 PM
  3. What is the Samung tab with best quality battery
    Last Post: 08-19-2016, 08:05 AM
  4. Charging Slow / Draining Fast While Switched Off???
    Last Post: 08-13-2016, 11:56 AM
  5. Replies: 1
    Last Post: 08-13-2016, 06:19 AM
