09-15-2016 04:48 PM
54 123
tools
  1. PJRed2008's Avatar
    Some of the apps that I had on the SD card showed a generic icon for a few minutes but they still worked. And the correct icon for each showed up after 20 minutes or so. Didn't have to do anything with them.
    According to other sources we're supposed to have FM radio now, Fulcan API support and better HD calling.
    09-01-2016 05:26 PM
  2. imex99's Avatar
    Still no Sprint update....
    09-02-2016 07:36 AM
  3. mru007's Avatar
    Mobile carriers generally decide when a phone will get an update. Even if Samsung has released the official OTA update, it may be delayed due to carriers.
    I have a Note 4, running Android 6.0 Marshmallow, & I have been regularly receiving monthly security updates (patches)......just received one 2 days back.
    Now Google's September security patch will be due in next 10 days or so.
    09-02-2016 07:51 AM
  4. munnarg's Avatar
    Ever since this update on my AT&T phone, my app permissions are all ****ed. I've had to go in and turn on permissions for almost every single app I've tried to use. If this continues I'm going to hard reset and start over.
    09-02-2016 07:55 AM
  5. lammy8's Avatar
    Vodafone UK here, got the update and I hate the new gallery. No option to have the big album previews
    EDIT: If you pinch to zoom in you can get the big previews back. Rather annoying to have it set like that beforehand
    imex99 likes this.
    09-04-2016 02:33 PM
  6. Sean Fanelli's Avatar
    Dang, att beat sprint..thats pretty sad
    09-04-2016 06:23 PM
  7. mmcclure0453's Avatar
    Agreed, battery is even worse on August patch with at&t
    Mine was doing bad after the patch for a day or so. Left it unplugged overnight and it went from 56% battery down to 18% just sitting on the night stand. Got really warm today and seemed to have crappie battery life. I did a restart and all has been well since. My battery seems to be back to normal now. Running cool and lasting like it did before I loaded the patch.
    09-04-2016 08:38 PM
  8. Sean Fanelli's Avatar
    Anyone on Sprint have it yet?
    09-04-2016 10:42 PM
  9. ThrottleJohnny's Avatar
    T-Mobile was on it for about 3 months, and now...nothing.
    I swear, hate to say it, but everyday I'm being pushed more and more towards an iPhone. : /
    09-04-2016 11:07 PM
  10. Sean Fanelli's Avatar
    Id swap yours for an unlocked version..not waiting on the carrier
    09-05-2016 09:14 PM
  11. pjwk81's Avatar
    Not much to be said for some of those either. I've an unlocked Exynos model and I'm on the July 1st update.
    09-06-2016 01:16 AM
  12. Alanhd's Avatar
    I received the update today. Unlocked UK. Says September 1st security patch.
    09-06-2016 06:25 AM
  13. aldo82's Avatar
    Thanks for the heads up, just checked and got the update here in the UK too
    09-06-2016 07:03 AM
  14. pjwk81's Avatar
    Any initial impressions of battery? And did it include the new gallery?
    09-06-2016 01:51 PM
  15. t11rmh's Avatar
    I applied the update just now and the gallery looks different.
    09-06-2016 06:45 PM
  16. chanchan05's Avatar
    What I hate about the new gallery is it showing numbers instead of the album name. I couldn't care less if the album hand 10 pictures or a thousand. It would be better to show the album name.
    09-06-2016 06:47 PM
  17. Alanhd's Avatar
    I'm still seeing the album names with the number of photos in each album.
    09-07-2016 04:13 AM
  18. chanchan05's Avatar
    Really? This is what I'm getting:
    Maybe I need to clear data or something.
    09-07-2016 04:33 AM
  19. aldo82's Avatar
    I get album names too.
    Android system drain quite high so far but will have to give it time to settle to really see how battery life compares
    09-07-2016 04:35 AM
  20. Alanhd's Avatar
    https://uploads.tapatalk-cdn.com/2016...f851c3b1d4.jpg
    I would try clearing the system cache as well as the gallery cache..
    09-07-2016 07:20 AM
  21. chanchan05's Avatar
    Apparently it was the theme I was using. It's not yet updated for the new gallery.
    09-07-2016 07:41 AM
  22. Alanhd's Avatar
    At least you know what's causing it, hopefully will be fixed soon.
    09-07-2016 11:12 AM
  23. chanchan05's Avatar
    I just went ahead and changed to another theme with similar colors.
    09-07-2016 02:02 PM
  24. Sean Fanelli's Avatar
    Still nothing on sprint...whats going on? Spetember is starting to go out in europe
    09-11-2016 06:05 PM
  25. imex99's Avatar
    Sprint update is live...
    09-13-2016 07:03 AM
54 123
  1. Replies: 18
    Last Post: 08-30-2016, 07:06 AM
  2. August security patch level for N beta
    By theduder in forum Android 7.0 Nougat
    Last Post: 08-16-2016, 11:34 AM
  3. Compatibility patch
    By ami.ben.ratzon in forum LG G3
    Last Post: 08-13-2016, 12:18 PM
  4. Compatibility patch
    By ami.ben.ratzon in forum Android 6.0 Marshmallow
    Last Post: 08-13-2016, 11:17 AM
  5. My WiFi connection is saved and secure - but not connected.
    Last Post: 08-11-2016, 09:52 AM
