1. stevealb's Avatar
    I finally found a screen protector for my S7 Edge that works well with a case. After 4 tries, I found Best Skins Ever (Samsung Galaxy S7 Edge Skin | Body and Screen Protection | Best Skins Ever). I bought the Case Fit Glossy screen protector and it's cut a little shorter and narrower so the edges do not get pushed up by a case. I'm using the Incipio case and all is well for the past month. Best Skins Ever customer service has been responsive as well.
    It took so long to find a screen protector to work with my S7 Edge and a case. I'm glad I didn't need to compromise. See the pictures of my phone with both case and screen protector.
    Finally a screen protector that works with a case-2411.jpgFinally a screen protector that works with a case-2414.jpg
    08-14-2016 12:28 PM
  2. dexterouz's Avatar
    That's a perfect fit there!!
    Thanks for sharing the link here
    08-14-2016 01:31 PM
  3. victoryrules8's Avatar
    Ordered one. Willing to try anything at this point just to see
    08-14-2016 05:53 PM
  4. popkurn611's Avatar
ID:	235072Click image for larger version.
    Is it a fingerprint magnet and dust collector? I had the iq shield and it was a total fingerprint magnet so I took it off after a week.
    08-14-2016 08:28 PM
  5. stevealb's Avatar
    Yes, it does collect dust and fingerprints, but only on the outside. Luckily, it only takes a wipe from a cloth to clean. I'd rather deal with dust and fingerprints and not scratches.
    08-14-2016 09:30 PM
  6. ThrottleJohnny's Avatar
    It's 9 dollars. I'll try it
    08-15-2016 12:21 AM
  7. jeetu4444's Avatar
    Iam using armor guard works great with s7 edge
    posted from Limited red and gold Lumia 950, Beautiful S7 Edge gold or Surface pro 4
    08-15-2016 07:05 AM
  8. eylan's Avatar
    I also ordered a ghostek case from uviyo.com that covers the whole phone. Anxious to get it and see how it works.Thanks for the info on the screen protector though
    08-15-2016 11:12 AM
  9. anon(19981)'s Avatar
    Keep us updated after a couple days on. I've had a few that I finally thought were the "One" but the would start coming up on a corner or rippling somewhere on the front. I haven't used BSE since my old BB Curve days.
    08-15-2016 08:18 PM
  10. stevealb's Avatar
    Just to clarify. The pictures I posted here with my phone is a smaller version of the Case Fit glossy screen protector. The regular Case Fit screen protector still came up at the corners with my case, but customer service was great and sent me a special version at no additional cost. That's what you see in the picture. If the regular Case Fit screen protector doesn't work, just ask customer service.
    08-15-2016 08:27 PM
  11. anon(19981)'s Avatar
    Just an FYI but if anyone is looking for a full screen protector I can honestly say that iCarez is by far the best ones I've tried. It's smooth like glass and it is a very easy install. It does very well with fingerprints and dust.
    08-15-2016 08:38 PM
  12. ChriRicerockets Rice's Avatar
    Thanks for the suggestion stevealb! Ordered one of these from BSE right after you posted. Can't beat full body protection for under $11! I ordered the glossy case fit since I use a UAG case. Couldn't be happier.
    On a side note, I didn't quite get the punch out at the microphone out (hanging chad anyone?) and once I out the case back on, no one could hear me!
    08-21-2016 08:10 PM
  13. mundo472's Avatar
    I've had this on for two months. Works great (if applied right). The only one that worked with cases. Used to use these and they worked almost as well as Ghost Armor.
    08-22-2016 09:10 AM
  14. eylan's Avatar
    I ordered one of those cases and the metal edges were really rough on my fingers and face. Did u experience the same?
    09-29-2016 10:36 AM
  1. Replies: 3
    Last Post: 08-14-2016, 10:09 PM
  2. Anyone Found a nice Holster Case?
    By pwscott in forum Samsung Galaxy Note 7
    Last Post: 08-14-2016, 03:31 PM
  3. My Galaxy S7 is stuck on the lock screen.
    By AC Question in forum Samsung Galaxy S7
    Last Post: 08-14-2016, 01:35 PM
  4. Replies: 0
    Last Post: 08-14-2016, 12:01 PM
  5. How to interact with single service with multiple activities
    Last Post: 08-14-2016, 11:56 AM
