1. Centerman66's Avatar
    Hi. I am brand new to Samsung getting my first galaxy phone (S7 Edge) Friday. I have one simple question. If I install and use nova launcher does this take the place of TouchWiz? Does nova remove or replace TouchWiz? Thanks all.
    Posted via my BlackBerry Priv
    08-16-2016 08:10 PM
  2. sicario666's Avatar
    It won't remove TouchWiz. It will just run over it.
    justpastfinish likes this.
    08-16-2016 08:12 PM
  3. Centerman66's Avatar
    So if there are TouchWiz features I like will they no longer be accessible ?
    08-16-2016 08:15 PM
  4. sicario666's Avatar
    I can test it out for you. I'm on an s7E and using nova. What is it you're looking for?
    08-16-2016 08:16 PM
  5. mia_xoxo's Avatar
    I believe most if not all of the TouchWiz features are in Nova Launcher. I use NL and I can still apply my widgets, adjust the icons. The Messaging app still looks and functions the same....hmmm I can't really think of anything else but you should be able to do everything you're looking for in TouchWiz on Nova Launcher but with some added bonuses.
    08-16-2016 08:39 PM
  6. Centerman66's Avatar
    Do all the edge functions work for example?
    08-16-2016 08:47 PM
  7. sicario666's Avatar
    Yes. They do
    08-16-2016 08:52 PM
  8. Centerman66's Avatar
    Excellent. Thanks for being so responsive you guys.
    08-16-2016 08:52 PM
  9. sicario666's Avatar
    Of course. No problem. That's what we're here for. Make sure you ask if you have any more questions
    08-16-2016 08:53 PM
  10. MikeRotch76's Avatar
    Same here, NL on TouchWiz. You can get the best of both worlds.
    08-16-2016 11:31 PM
  11. pjwk81's Avatar
    Only issue I ever had is that it doesn't pick up the Samsung theme icons.
    08-17-2016 01:41 PM
  12. UBiggo's Avatar
    It won't delete TouchWiz or anything like that. You will be able to choose which launcher you want to use. And launchers only change the appearance of the home screen and such so the quick controls you see when you drag down with your finger will still be there.
    08-17-2016 02:48 PM
  13. mlblack16's Avatar
    I like tesla unread count which is made by the same developer as nova launcher. It allows you to create unread count bubbles for almost any app, but especially Gmail, which for some unknown reason touch wiz doesn't do.
    08-17-2016 05:56 PM
  14. mlblack16's Avatar
    I should add, the only way to use tesla unread count is to run Nova Launcher as your home replacement
    08-17-2016 05:56 PM
  1. Replies: 5
    Last Post: 08-20-2016, 04:37 AM
  2. Backup/Restore using Samsung smart switch.
    By Frankie Yaw in forum LG G4
    Last Post: 08-17-2016, 07:08 AM
  3. Can I use the Sony Xperia X series on Verizon?
    By Slycooper91 in forum Ask a Question
    Last Post: 08-16-2016, 07:49 PM
  4. How many Nougat features will make it to 3rd party launchers?
    By Antony Guan in forum Android 7.0 Nougat
    Last Post: 08-16-2016, 06:51 PM
  5. Changing grid size with other launchers.
    By Dhawk1202 in forum Samsung Galaxy Note 7
    Last Post: 08-16-2016, 06:45 PM
