1. Johnred's Avatar
    Does anyone else have any problems with typing on the edge? My problem is that every keyboard I've used and I bought and tried alot of them I currently using SwiftKey now I ALWAYS end up hitting the ( . ) I have tried alot of Keyboards I've tried hiding it different but this is so frustrating on the iPhone I noticed that the ( . ) is not on the keyboard I guess the space bar does it... This phone is the only one that I have a problem with I've had many androids... If you have any advice on a keyboard that I can remove it that would be great... I'm open to all suggestions hopefully beneficial suggestions.
    Thanks for your help
    08-16-2016 09:28 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. A double space may end the sentence. Is there anything in settings to turn this off? It may bring the period back to the keyboard.
    kjung7 likes this.
    08-16-2016 09:47 PM
  3. chanchan05's Avatar
    Seems like you just need to get used to the keyboard layout.
    08-17-2016 02:36 AM
  4. Tswfootball's Avatar
    Haven't swiftkey altered the keyboard for the edge phones? It has for me in such a way that the edges of the keyboard are blank
    08-17-2016 03:56 AM
  5. chanchan05's Avatar
    His problem isn't the keys on the edge. It's the period button beside the spacebar.
    08-17-2016 06:51 AM
  1. Unable to access bitmoji on keyboard on S7
    By yongkoh89 in forum Android Apps
    Last Post: 06-08-2017, 02:04 AM
  2. Replies: 2
    Last Post: 08-29-2016, 01:54 AM
  3. Replies: 1
    Last Post: 08-16-2016, 11:20 AM
  4. Can't Make Blackberry Keyboard the Default in LG G4
    By johnts in forum Android Apps
    Last Post: 08-15-2016, 01:47 PM
  5. Replies: 0
    Last Post: 08-15-2016, 12:35 PM
