1. randomgecko's Avatar
    I purchased two wireless charging pads from eBay for £7 each. Too good to be true I know, but worth a try. They seemed to work fine for the first few days, but this morning I woke up to find my phone was only at 78% despite being on charge all night. A quick blast with the fast charging plug and it was up to 100% in no time.
    I am using a plastic case, so I'm not sure if thats it, but I was the night before too.
    I've now ordered an official fast charge pad but in the meantime, is there any danger using these fake pads? Any potential damage to the battery etc?
    08-17-2016 06:53 AM
  2. dpham00's Avatar
    They could generate more heat and charge slower, or stop charging due to poor connection
    08-17-2016 07:18 AM
  3. randomgecko's Avatar
    Is that gonna endanger the phone in any way?
    08-17-2016 07:21 AM
  4. Iva_LadyDiCaprio98's Avatar
    It could make the phones battery hotter than usual so I personally wouldn't ever use any wireless charger outside of samsung
    08-17-2016 07:31 AM
  5. Almeuit's Avatar
    I wouldn't do it. The heat could cause issues if it isn't done right. I use the actual Samsung fast charger and it works like it should.
    08-17-2016 07:48 AM
  6. randomgecko's Avatar
    The other thing is, the pad isn't turning green any longer. It did previously, but now the phone is showing the green light at the top but the pad is still blue and pushing charge.
    08-17-2016 07:49 AM
  7. jeetu4444's Avatar
    Iam using pleson fast wireless charger works great...try this one
    posted from Limited red and gold Lumia 950, Beautiful S7 Edge gold or Surface pro 4
    08-17-2016 07:56 AM
  8. Iva_LadyDiCaprio98's Avatar
    If I were you I would just get the Samsung wireless charger. It's worth the money and you'll know that your phone won't get damaged in the process. When it comes to my phone being an $800 device I would never choose the cheap option for charging accessories. I always go with manufacturer.
    IAmSixNine likes this.
    08-17-2016 09:00 AM
  9. jazz70's Avatar
    I have both the Samsung Fast Charger and the Seneo Fast Charger and in my experience with the $25 Seneo it charges just as fast as the $50 Samsung with no overheating problems
    08-17-2016 09:45 AM
  10. IAmSixNine's Avatar
    Sure lets buy the 700+ phone then skimp on how to charge it. Nothing wrong with that. ha ha ha.
    Whats the worst that can happen. Burn up the phone or house maybe? So with that said wireless charging needs to be as close to the phone as possible. Take off the phone case and test it and see if you get better results. In theory you should.
    Any excessive heat is bad on a phone. Always remember that.
    When dealing with electronics its OK to buy stuff that is not from the manufacturer but still try to stick with reputable brands. Cheap chines nock off crap is just that crap and because its electrical can be dangerous.
    08-17-2016 11:15 AM
  1. Nexus 5X - Why charging still drains battery?
    Last Post: 08-24-2016, 03:05 AM
  2. Dash Charge Powerbank?
    By ZeevoX Mult in forum OnePlus 3 & 3T
    Last Post: 08-17-2016, 12:01 PM
  3. android phone is completely dead not even showing charge symbol
    By maanjunadha in forum General Help and How To
    Last Post: 08-17-2016, 01:27 AM
  4. Replies: 0
    Last Post: 08-17-2016, 01:08 AM
  5. Replies: 0
    Last Post: 08-16-2016, 11:21 PM
