1. jon93c's Avatar
    Hey I have a problem with this phone (had it with the s6 edge too) and that's the fact that this phone is way too smooth and creates very little friction. This is a problem because every time I sit down the phone slips out of my pockets and falls on the ground. Sometimes I even put it back into my pocket after it falls out while I'm sitting, and it falls out again without me moving... If it wasn't for the high quality materials this phone would be in pieces by now. I tried (for the s6) getting a case that might have a little more friction to stop it from sliding all over the place like an ice skater but it didn't help much. I'd like to find a solution before my s7 either cracks or falls out without me noticing and I lose it. Anyone have any ideas?
    08-18-2016 12:22 PM
  2. SpookDroid's Avatar
    Other than getting a rough case or a textured skin for the back, I can't see what else you could do other than NOT keeping it in your pocket. I don't have that issue, but I'm using a case with it (sometimes a Spigen slim-fit case, sometimes a Spigen rougher one with a kickstand).
    You can also try to saw part of your pocket opening so that the top part is open and wide enough for the phone to go in, but once it's in, the phone drops to the bottom part of the pocket where the opening is sawed (sort of like a pocket inside a pocket).
    08-18-2016 12:29 PM
  3. Roman Akert's Avatar
    This is a wind-up right?
    08-18-2016 02:02 PM
  4. IAmSixNine's Avatar
    ha ha.. get bigger pants.
    i cant tell you how many chicks i have seen that have a big phone that sticks up about 2/3 out of their pockets.
    Giant phone + skinny jeans = expensive repairs.
    like our ambassador said, try different cases.
    08-18-2016 03:38 PM
  5. edubb256's Avatar
    I put a slickwraps skin on mine. Problem solved.
    08-18-2016 05:00 PM
  6. t11rmh's Avatar
    Treat your phone with a bit more care. Pockets damage them.
    08-18-2016 05:16 PM
  7. SpookDroid's Avatar
    Nope, stuff in pockets do. Unless you have sand-paper pockets, then yeah, pockets do the damage (and I'd recommend fabric softener if that's the case :P)
    libra89 and Alan Sims like this.
    08-18-2016 06:10 PM
  8. javi9600's Avatar
    Had to put a Spigen Slim Armour case on my edge. That greatly help to take care of the problem.
    08-18-2016 07:05 PM
  9. Joshua1276's Avatar
    Currently using the Spigen for weekends and Supcase+Holster for work. Spigen works pretty well for grip. With that being said I would suggest something bulkier for your situation like the Supcase just to give that piece of mind. Cant beat the price either.
    08-20-2016 07:07 PM
  10. underway99's Avatar
    I have a Spigen Neo-Hybrid case. It's a TPU case with a plastic ring. Not slippery at all in the pocket.
    08-20-2016 07:38 PM
  11. jfs101's Avatar
    The Spigen rugged armor is a great case. I use it and the UAG which protects more. I would recommend to you the Spigen case as it's very minimal.
    08-20-2016 08:46 PM
  1. Replies: 2
    Last Post: 12-03-2016, 05:01 AM
  2. my phone is showing error ero5 invalid sim
    Last Post: 08-25-2016, 04:20 AM
  3. Dus your phone hav to be on to use go sms pro
    Last Post: 08-25-2016, 04:17 AM
  4. Amazon flash in my fire phone but the phone does'nt start
    By Dubond2011 in forum Amazon Fire Phone
    Last Post: 08-18-2016, 11:58 AM
  5. What to do while waiting for your UK version of the Note7? RTFM
    By IMissMyPsion in forum Samsung Galaxy Note 7
    Last Post: 08-18-2016, 11:41 AM
