1. AC Question's Avatar
    I have a S7 edge and my screen froze during a download. I didn't know how to do a soft reset so I let the battery run out I then placed it o my charger after the battery died and it froze on the charging screen. I learned hot to reset and have gotten into Android
    recovery. I have tried to wipe cache which comes up with a lot of red E :failed invalid argument. the same happens with wipe data factory reset. Any reboot I do takes me back into the same menu with no progress. Any help is appreciated
    08-19-2016 06:21 AM
  2. Javier P's Avatar
    Mod note. Moved to S7 Edge forum for more visibility.
    08-19-2016 06:33 AM
  3. meyerweb#CB's Avatar
    What were you trying to download? A system update, or an app?
    Have you fully charged the phone? Turn it off, let it charge for a couple of hours, then power it back on and see what happens.
    08-19-2016 07:19 PM
  1. Why failed to play... unknown error has occurred?
    Last Post: 01-04-2017, 12:55 AM
  2. Note 7 fail, gif maker features removed
    By Derek Faircloth2 in forum AT&T
    Last Post: 08-19-2016, 05:27 PM
  3. Replies: 0
    Last Post: 08-18-2016, 11:58 PM
  4. Replies: 0
    Last Post: 08-18-2016, 11:05 PM
  5. Samsung "pop up" store fail
    By miketko in forum Samsung Galaxy Note 7
    Last Post: 08-18-2016, 10:19 PM
