1. mar29020's Avatar
    Can anyone explain why my phone drains from just sleeping?!
    08-19-2016 02:21 PM
  2. dhawalpateldp60's Avatar
    It seems there is some app or a process which is keeping your phone active and your phone is not entering deep sleep. Try these if you are rooted download wakelock detector and see which app is draining the battery. or go to mobile network and manually choose your network & if u only use 2g then change the network mode to 2g only. If all else fail factory reset (wipe cache ). Hope this helps.
    08-19-2016 02:59 PM
  3. mar29020's Avatar
    im not rooted but i will try the options you listed. if that fails ill just charge it over night
    08-19-2016 03:20 PM
  4. Leslie Hatcher's Avatar
    Also, clearing your cache is helpful.
    08-22-2016 08:06 PM
  5. t11rmh's Avatar
    Bad signal area?
    08-23-2016 02:25 PM
  6. Javier P's Avatar
    Bad signal area?
    I'm inclined to agree with this. In your screenshot the signal seems to be weak.
    08-23-2016 03:10 PM
  1. Samsung Smart Switch isn't compatible with your device
    By ccpopham in forum Samsung Galaxy Note 7
    Last Post: 08-19-2016, 06:36 PM
  2. Replies: 3
    Last Post: 08-19-2016, 02:07 PM
  3. Samsung galaxy j5 battery
    Last Post: 08-19-2016, 01:26 PM
