1. Conor78's Avatar
    When I moved to the edge I basically set it up the same as my iPhone 6 and didn't use widgets. What's the best way to incorporate widgets??what are the best ones to use?
    08-20-2016 03:38 AM
  2. Jtshurtleff's Avatar
    It'll probably take a little while before you know which ones to use. I take a lot of notes and make grocery lists so I have the Keep widget on one screen. I listen to Google Play music a lot so I have a widget with the controls for that, the Google widget is always useful as is weather and I have the GSam widget for battery performance at a glance.
    08-20-2016 05:03 AM
  3. dm3ready's Avatar
    I use Outlook for Android and use their email and calendar widgets + HD widget for weather + Todoist widget for my to-do list.
    Widgets on the home screen are what keep me on Android!!
    08-21-2016 08:24 AM
  1. How do YOU use the S-pen for notes
    By ChiefJaguar in forum Samsung Galaxy Note 5
    Last Post: 08-20-2016, 08:08 PM
  2. How to use the Turbo Charger
    By SteelSteve in forum Moto Z Force
    Last Post: 08-20-2016, 07:47 PM
  3. Replies: 1
    Last Post: 08-20-2016, 06:45 AM
  4. Remotely using phone?
    Last Post: 08-19-2016, 04:36 PM
  5. Using Google Voice instead of Samsung Voice for dictation
    By French in forum Samsung Galaxy Note 7
    Last Post: 08-19-2016, 03:15 PM
