1. RJurman's Avatar
    Not sure if anyone has received this yet but mine came last night. My first android security update since the May update this phone shipped with.
    I am on the unlocked SM-G935U on the AT&T network. Patch level August 1, 2016 and rolled in around 147mb
    08-23-2016 07:03 AM
  2. mitul_mehta's Avatar
    That's strange. Every month there is a patch that comes out. This month patch was of around 151 MB for India users. If u hadn't received any of the previous month patches then the update package size would be much much higher.
    08-23-2016 07:13 AM
  3. RJurman's Avatar
    The 935U USA uulocked only came out a couple of months ago and shipped with the May update. I have not seen any updates since and check frequently.
    08-23-2016 07:21 AM
  4. terp05's Avatar
    I received my update this morning. 164.13 MB, August 1 security patch level and running build MMB29M and G935UUEU2APG9 baseband
    Are we the first S7Edges in the US on the August patch level?
    08-23-2016 10:31 AM
  5. buddhake's Avatar
    Yep I got mine this morning too
    08-23-2016 12:17 PM
  6. optimummind's Avatar
    Got mine as well on the Sprint 935P GS7 Edge running on the 935u rom.
    08-23-2016 07:42 PM
  7. shanghaichica's Avatar
    Did you get the new cloud and gallery features with your update?
    Posted from my pink gold S7 edge
    08-24-2016 12:53 AM
  8. RJurman's Avatar
    I have really not noticed any real difference with this update. There is now a Google menu but that's all I have seen so far
    08-24-2016 07:36 AM
  9. hishaq96's Avatar
    No August update in the UK yet
    08-24-2016 11:35 AM
  10. Jayjit Biswas's Avatar
    Yes Gallery with cloud in Indian update
    shanghaichica likes this.
    08-24-2016 12:54 PM
  11. shanghaichica's Avatar
    My update just came through this morning. Will check if it has said new features.
    Edit: yes the cloud and gallery features are there.
    08-25-2016 05:16 AM
  1. Replies: 22
    Last Post: 02-06-2017, 07:31 AM
  2. Replies: 2
    Last Post: 09-04-2016, 12:46 AM
  3. Galaxy s7 edge keeps going into android recovery!
    Last Post: 08-23-2016, 06:39 AM
  4. Replies: 1
    Last Post: 08-23-2016, 05:14 AM
  5. G930U gets August Security update
    By Enverdaz in forum Samsung Galaxy S7
    Last Post: 08-23-2016, 03:08 AM
