Hi
As you all know most Android devices inevitably have to suffer from the Battery Drain coming from the high percentage usage of the Android System or Android OS showing in the battery stats.
I am also suffering the same with my s7edge. I know rebooting or factory resetting fixes it but temporarily.
Is there a permanent fix to this problem.
Thanks in advance
Thanks in advance
