1. shoaib shah's Avatar
    Hi
    As you all know most Android devices inevitably have to suffer from the Battery Drain coming from the high percentage usage of the Android System or Android OS showing in the battery stats.
    I am also suffering the same with my s7edge. I know rebooting or factory resetting fixes it but temporarily.
    Is there a permanent fix to this problem.
    Thanks in advance
    imex99 likes this.
    08-23-2016 12:55 PM
  2. Bleezy's Avatar
    If there was an answer to this, we'd all know by now. Ive researched various sites and there isnt a clear answer. All you can do is disable the bloatware, and turn off everything you're not using (wifi, blutooth, gps, etc) and close out the apps running in the background when you're done using them. There isnt very much beyond that.
    08-23-2016 06:39 PM
  3. access101's Avatar
    08-23-2016 09:34 PM
  4. shoaib shah's Avatar
    Thanks
    That's a very big thread which page actually tells you some fixes for battery drain
    08-24-2016 01:46 AM
  5. Jdroids's Avatar
    Make sure to keep location history and improve accuracy turned off under location setting. That's one of the biggest hitter for stand by drain. Doing so wouldn't hinder use of map or any location based service.
    Bleezy and HMBgal like this.
    08-24-2016 02:39 AM
  6. access101's Avatar
    Get package disabler pro from the play store and use the menu to select disable bloatware. Also disable qualcomm.atfi. this made my battery life rock!
    GoreJak likes this.
    08-24-2016 07:53 AM
  7. t11rmh's Avatar
    Stay in a good signal area.
    08-24-2016 11:46 AM
  8. Bleezy's Avatar
    .......also disable qualcomm.atfi. this made my battery life rock!
    What does "qualcomm.atfi" even do? haha
    08-24-2016 05:58 PM
  9. access101's Avatar
    Sorry qualcomm.atfwd. it is a TV mirroring service. Ate a lot of my battery. I don't use it.
    08-24-2016 06:07 PM
  10. KPMcClave's Avatar
    That is one of the packages that runs regardless of being disabled, though (go check it on the More tab of EZ Disabler...it will be running). The thought a while back when we were discussing this in another thread was that those packages that run anyway seemed to use more battery when disabled. I enabled any that insisted on running regardless of active status.
    08-24-2016 08:30 PM
  1. Pictures are not downloading to the gallery
    By golfergirl13 in forum Samsung Galaxy Note 7
    Last Post: 09-23-2016, 11:52 AM
  2. Can I fix the Galaxy Note 7 texting?
    Last Post: 09-12-2016, 12:58 PM
  3. Replies: 1
    Last Post: 08-30-2016, 04:36 AM
  4. Wallpaper reverts back to starry sky wallpaper...
    Last Post: 08-25-2016, 11:55 PM
  5. Is this Samsung Fast Charger safe to use with my Note 7?
    By felloffthetruck in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 07:31 PM
