1. YMarkY's Avatar
    Can some kind person solve my riddle??
    I was using Flipboard and was going to "share" an article via text message. I clicked on Textra (as this was my messaging app) and sent the link. However, I no longer use Textra (but haven't uninstalled it) and would like to change the app that I use for sharing a Flipboard link.
    Anyone have any idea how to change or remove an app used for sharing? I've tried "Better Open With" in the app store but that doesn't work. Seems like this is native to Marshmallow or Samsung. I've done some searching and it seems like you used to be able to "clear" shared apps in the App Manager prior to this release.
    Thanks for any help.
    08-23-2016 06:19 PM
  2. B. Diddy's Avatar
    You could try Reset All App Preferences (usually in the App Manager, then tapping More). Or go to the App Manager, select Flipboard, and Clear Cache/Data.
    08-24-2016 03:27 AM
  1. how can I sync calendars bewteen 2 galaxy s7 edge?
    Last Post: 08-30-2016, 05:50 AM
  2. Changing Tomorrow from ATT to T-Mobile. What to Expect?
    By MerpsMom in forum Samsung Galaxy Note 5
    Last Post: 08-28-2016, 12:30 PM
  3. How can I show text message content on locked screen?
    Last Post: 08-23-2016, 06:15 PM
  4. Replies: 0
    Last Post: 08-23-2016, 06:01 PM
  5. Why am I not able to share pictures to my google account?
    Last Post: 08-23-2016, 05:44 PM
