Save big + get 3 months free! Sign up for ExpressVPN today
  1. 1iwilly's Avatar
    ok guys i have a trick not original but it does give faster access to data toggler not on the notification bar but on home screen i came up with this after reading this tread=
    hxxp://forum.xda-developers.com/tmobile-s7-edge/help/built-caller-id-hidden-t3357996[/url] for the incoming caller ID hack. here is the GPLAY link for the app=hxxps://play.google.com/store/apps/details?id=com.sika524.android.quickshortcut well with that app i did a data search look for phone com.android phone then you click on it to branch it then tap on mobile data then create short cut and bingo no more clicks after clicks. then i found a image of a setting with the data toggle image took a picture of it edit it to smaller size and swap it with the phone image like i said not perfect but it will do for me. hope this help others her is image of it maybe somebody can make a nicer data icon image.
    Attached Thumbnails my simple data toggle for the s7 edge-screenshot_20160823-201234.jpg   my simple data toggle for the s7 edge-screenshot_20160823-201337.jpg
    08-23-2016 07:28 PM
  2. 1iwilly's Avatar
    wow 100 views must be old news been o thought this is easier simpler than using other app
    08-24-2016 04:18 PM
  3. 1iwilly's Avatar
    added app link on gplay store forgot to do that when i wrote it
    08-25-2016 01:09 PM
  1. How to unblock my pin? sim lock on family mobile
    Last Post: 09-27-2016, 04:00 PM
  2. Unsupported SD on my s7?
    Last Post: 09-27-2016, 03:59 PM
  3. Why isnt my Galaxy s7 playing my music loud with aux cord?
    Last Post: 08-30-2016, 05:01 AM
  4. S6 Edge slow car charge
    By Chilllmatic in forum Samsung Galaxy S6 edge
    Last Post: 08-29-2016, 06:04 PM
