1. Abby Normal's Avatar
    So the actual install is pretty straight forward........ I bought the SanDisk Ultra and with it came a smaller chip which I believe to be a sim card... Correct ???
    Anyway, where I open card holder there already is what I believe to be a verizon sim chip in the holder.....
    So do I leave the verizon one alone and insert the SD card only....or do I remove the verizon chip and install the two that came from SanDisk ????
    08-24-2016 08:35 AM
  2. gmaister22's Avatar
    The smaller chip is the micro SD card that you put on your phone. The big one is just an adapter. Your Sim card tray should have 2 cards, the Verizon and the SanDisk
    Abby Normal likes this.
    08-24-2016 08:37 AM
  3. Abby Normal's Avatar
    So if I understand this correctly.,..... The SanDisk adapter is not required for the S7edge.... I leave the verizon in and add the small SD card from SanDisk....
    08-24-2016 08:51 AM
  4. gmaister22's Avatar
    Yes correct
    08-24-2016 08:52 AM
  5. Abby Normal's Avatar
    Thanks for your help.......
    08-24-2016 08:58 AM
  6. Roynato's Avatar
    This picture should help you.
    floflo likes this.
    08-24-2016 01:52 PM
  1. Always On Display Not Working
    By twan83 in forum Samsung Galaxy Note 7
    Last Post: 08-24-2016, 04:37 PM
  2. How do i backup files on zte tmobile osidian before rooting
    Last Post: 08-24-2016, 01:15 PM
  3. Why is my LG G3 SD card not showing anything?
    Last Post: 08-24-2016, 12:55 PM
  4. Replies: 0
    Last Post: 08-24-2016, 08:00 AM
  5. how do i turn mobile data on on my samsung galaxy s7?
    Last Post: 08-24-2016, 07:56 AM
