05-02-2017 04:34 AM
69 123
tools
  1. jeetu4444's Avatar
    Here is the best i have got from my S7 edge battery life exynos version unlocked dual simAttachment 237508S7 edge battery drain, please help-screenshot_20160826-185725.jpg
    Posted via Limited Edition Lumia 950 with Mozo Case or Beautiful Gold S7 Edge or Surface pro 4 or Lumia 1020 or motoe or iphone 5s
    08-28-2016 09:32 AM
  2. Ripley's Avatar
    hi
    i had a bit of battery drain myself on my s7 edge
    what really worked for me and in fact has saved me about 30%-40% battery is uninstalling the facebook and messenger app
    i now use metal for facebook, it doesn't show in the battery stats but facebook is a real battery hog...give it a try
    hope it helps
    08-28-2016 04:17 PM
  3. danielbroadwell5's Avatar
    hi
    hope it helps
    I don't have a Facebook so I haven't ever had Facebook on my phone. But yes I agree with you I know of many people that Facebook and Facebook messenger is a huge battery hog.
    08-28-2016 04:20 PM
  4. danielbroadwell5's Avatar
    Here is the best i have got from my S7 edge battery life exynos version unlocked dual simAttachment 237508Click image for larger version.
    Wow that's good too! Was that just with common use? Like texting, calling, some social media?
    08-28-2016 04:20 PM
  5. jeetu4444's Avatar
    Daily use with social apps like facebook instagram snapchat and calls little gaming...even apps like android central and wp central..little bit of mobile hot spot
    08-29-2016 06:15 AM
  6. danielbroadwell5's Avatar
    Wow! That's very impressive lol. Never would my phone even dream of doing that. Do you have good service all day then?
    08-29-2016 06:23 AM
  7. TylerLV76's Avatar
    I may have found something to help you a bit. Since you have wifi calling active you can put your phone in airplane mode at work then turn wifi back on and connect to it. Your calls will automatically route through wifi calling as well as text messages but your phone will stop searching for cell signal. This may add some decent battery life to your phone.
    08-31-2016 09:51 AM
  8. danielbroadwell5's Avatar
    I used to do the whole airplane mode thing before I got important text messages lol. But I'm pretty sure if I go in airplane mode and even turn my wifi on it still won't allow text messages that's why I couldn't do it.
    08-31-2016 03:00 PM
  9. TylerLV76's Avatar
    It does allow text messages over wifi. Weve been playing with it all day and so far havent lost any functionality.
    08-31-2016 03:03 PM
  10. danielbroadwell5's Avatar
    Oh wow! Okay must have changed. I haven't tried that in a long time. I'll have to give it a try and let you guys know how it goes. Thank again!
    08-31-2016 03:04 PM
  11. ronin_cse's Avatar
    hi
    hope it helps
    Why wouldn't facebook show up in the battery stats if it's such a huge battery hog?
    08-31-2016 03:54 PM
  12. Galaxy s7 edge's Avatar
    11-07-2016 11:21 AM
  13. Galaxy s7 edge's Avatar
    I have the same problem
    11-07-2016 11:22 AM
  14. Ds Vtoutain's Avatar
    Where can I find the "answer" - you mentioned to skip to the answer on how to get rid of bloatware, but there are over a hundred pages. Not sure where the info is. Any help finding it would be appreciated!
    01-01-2017 07:50 PM
  15. Ds Vtoutain's Avatar
    PS I downloaded the package disabler pro...but not sure which system apps are safe to disable - there are so many things listed! Any advice?
    01-01-2017 07:55 PM
  16. PAC757's Avatar
    My AT&T Note 5 has horrible battery life 9.5 hours total on time, I found that the problem is always a weak cell signal. I used LTE Discovery app and found the problem is my phone keeps grabbing onto LTE Band 30 which averages - 112 db. It's making the phone useless there seems no way to force it to change LTE bands. I proved this by putting my SIM card in a phone that does not have band 30 and my average signal strength on bands 2 and 17 is - 89. Cell signal is killing my Note 5 to the point I'm ready to get rid of it.
    03-08-2017 05:47 AM
  17. danielbroadwell5's Avatar
    I actually got rid of my note 5 because of its horrible battery life. With all new phones it's awesome for the first couple months then a couple updates come out and then the battery is awful. I have the s7 edge (US model) now and it's better but not really good battery life like everyone saids the International model does.
    03-08-2017 05:55 AM
  18. Cool Android's Avatar
    Go to mobile networks in setting and change to LTE ONLY OR 3G ONLY
    Attached Thumbnails S7 edge battery drain, please help-screenshot_20170319-142943.jpg
    03-19-2017 07:30 AM
  19. moeong's Avatar
    I have the same problem after going to nougat, s7 edge with 25-30% remaining battery life. It suddenly shuts down with status of 0% battery. Anyone encountered this?
    Tried wiping my cache already to no avail. Haven't tried resetting to factory yet. Also currently changed my charger cable since there is an exposed wiring already not sure if there is an affect here on the battery charging. So will update tomorrow if the changing of cable wiring worked.
    EDIT:
    Changed my cable but still after 35% of battery life it dropped to 0. Anyone has any solution here?
    05-02-2017 04:34 AM
69 123
  1. Help!! LG phone locked out by FBI scam. what to do?
    By Katreq in forum LG Optimus Series
    Last Post: 08-25-2017, 06:55 AM
  2. Freaking terrible standbytime! Please help!
    By Mooserman15 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 09-21-2016, 09:32 PM
  3. Curved edges interfere with note taking
    By 2ndHalfCor in forum Samsung Galaxy Note 7
    Last Post: 08-25-2016, 04:55 PM
  4. Help! Blackberry bricked
    By kach474 in forum BlackBerry Priv
    Last Post: 08-25-2016, 10:17 AM
  5. Galaxy S6 Constant Freezes and Reboots. Need Help.
    By fritzo81 in forum Samsung Galaxy S6
    Last Post: 08-24-2016, 10:26 PM
