05-02-2017 04:34 AM
69 123
tools
  1. Hock3y Monk3y29's Avatar
    I have the S7 edge, and I really like the phone, but I got it because it was supposed to have amazing battery life. I got the phone, and get about 17 hours on battery (not bad) but with 3 hours of screen on time, I thought I was supposed to get 6+ hours? I have tried everything, clearing system cache, factory reset, turned off all the extra features that use the sensors, I even downloaded greenify and use doze on the go too. I just don't know what else to do. GSAM battery app indicates that my wifi is taking nearly 50% of my battery...but I don't know what to do about a wifi battery drain. I do text, snapchat, and groupme a ton throughout the day, but again, 3 hours of screen on time. I also lose about 4% per hour on standby, someone please help.
    Screen shots with battery info is here: https://drive.google.com/open?id=0B7...WRzQjh1anR6eFE
    Ripley likes this.
    08-24-2016 07:49 PM
  2. access101's Avatar
    08-24-2016 07:52 PM
  3. access101's Avatar
    Also skip to the answer. Download package disabler pro and use the menu to disable bloatware.
    freeop likes this.
    08-24-2016 07:53 PM
  4. danielbroadwell5's Avatar
    I agree. I have the s7 edge and the first 2 weeks I had it i got close to 4 hrs screen on time and now with my gear s2 connected to it and tons of features turned off I only get 2hrs 2 and a half hrs screen on time. Android system is my biggest battery eater. Now I quit using my gear s2 and now I can get 3 hrs screen on time but nothing much more. People say they get 5-7 hrs screen on time and it's hard to believe. I have the Verizon s7 edge with the Snapdragon processor.
    08-24-2016 07:59 PM
  5. chanchan05's Avatar
    1 get over 4hrs screen time and over 17hrs standby time.
    I suggest you guys clear system cache via the recovery menu. Sounds like some junk files were retained and still running.
    08-25-2016 12:23 AM
  6. danielbroadwell5's Avatar
    I always wipe my cache. About once a week. I even did the factory boot and wiped system cache by holding the volume up button and home button. Yesterday I got 3hrs screen on time. (No gear s2) Once I connect my gear s2 I'll get around 2-2.5hrs screen on time. I always thought a watch would help save battery because it wouldn't require turning on your screen to check your phone all the time. Always clear my recent apps. Also have tons of toggles and bloat ware apps disabled. Been using Samsung since the s4 and worked for Samsung inside bestbuy. None of this stuff is new, is it just the Qualcomm version that has issues? Ik the exynos Samsung processor people report 6-7 hrs screen on time. That's insane and I've never had a smartphone do that. I don't even have Facebook! Which is a huge battery eater.
    08-25-2016 06:22 AM
  7. chanchan05's Avatar
    Well I do have the Exynos version, I Facebook quite a bit, and is connected online via WiFi or mobile internet for the better part of the day.
    08-25-2016 07:21 AM
  8. danielbroadwell5's Avatar
    Wow, my wifi is set to the keep wifi on during sleep. Since it's supposed to save power and I still only get the battery life I stated above.
    08-25-2016 07:24 AM
  9. Nodnerb's Avatar
    I found having keep wifi on during sleep was what was causing most of my battery drain. Android system was using anywhere from 30-50% of my battery. As soon as I turned "keep wifi on during sleep" off it has gone down to a more reasonable 10-15%.
    08-25-2016 07:41 AM
  10. danielbroadwell5's Avatar
    Android system is still my largest battery drain is that normal?
    08-25-2016 07:47 AM
  11. danielbroadwell5's Avatar
    1hr 55 mins screen on time.....
    08-25-2016 04:13 PM
  12. chanchan05's Avatar
    Try using GSAM to record your average battery stats.
    08-25-2016 05:23 PM
  13. danielbroadwell5's Avatar
    Okay I will post my stats tmrw.
    08-25-2016 05:28 PM
  14. popkurn611's Avatar
    I as well am having the same issue as you are. Android System is at the top of my stats every day. I wipe cache over three times a week which does absolutely nothing and I am getting 2.5-3 hours SOT. I have the snapdragon processor on AT&T. I wouldn't even consider myself a power user, It is on standby most of the day during my work hours. I use Google play in the mornings at the gym which is a huge battery eater, Bluetooth headphones as well. I have a zenwatch 2 that doesn't really seem to affect my battery life, although I haven't tested it enough to say so.
    08-25-2016 08:31 PM
  15. danielbroadwell5's Avatar
    Idk what it is, but I hate to say my rooted note 3 back in 2013 would outlast this phone easily. I'd pull out 2 days with it. I mean I hear praise about the Samsung exynos processor and I haven't had anything against Qualcomm. But my phone gets hot just after using it for about 5 mins straight with the brightness set to auto. Paying 792 bucks for a smartphone it should be rather good I would think since this is Samsungs flagship.
    08-25-2016 08:35 PM
  16. danielbroadwell5's Avatar
    Well here it is without Bluetooth on.
    08-26-2016 08:30 PM
  17. TylerLV76's Avatar
    Where it says apps 62%, what apps are in there?
    Im not sure whats running on your phone but Im at 73% right now with 2 hours screen on time. This is my 2nd S7 edge and both of them average 7 hours with bluetooth off.
    08-26-2016 09:28 PM
  18. danielbroadwell5's Avatar
    Wow that is crazy! Okay at the end of today I'll give both. But I remember the top was android system and then android OS. there is no way I could have 73 percent at the end of the day with 2 hrs screen on time. That is awesome for you though!
    08-27-2016 07:15 AM
  19. TylerLV76's Avatar
    So you know, Im not trying to brag about my battery compared to yours. Just letting you know it is possible to get great life out of this phone, just gotta figure out whats causing yours to go nuts. I turn alot of stuff off because I dont use it so I'll give you an idea of my settings and see how they compare to yours. Remember, I dont use the stuff I turn off so some of these may not suit your needs. These are the settings that should make the most difference.
    Display:
    I use AMOLED cinema mode for screen mode, auto brightness, timeout after 30 seconds, smart stay off, always on display on only at night normally while on the charger, touch key light 6 seconds, keep screen turned off toggle off, screensaver off.
    Advanced Features:
    I turned off all the sensor related gestures in the adavnced features tab. pop up view, smart capture, palm to swipe etc etc. I dont like any of them.
    Privacy and Safety:
    I only use location when I need it but even with it on I still get over 6 1/2 hours screen on time. Report diagnostics off
    Google:
    Nearby off, search & now > voice> "ok google" detection from the google app and from any screen toggles on. Trusted voice off.
    NFC is also off because I use Samsung pay instead of Android pay. Im not sure how much NFC affects the battery.
    Tsepz_GP likes this.
    08-27-2016 07:33 AM
  20. Jamie Wooten's Avatar
    Display:
    Advanced Features:
    Privacy and Safety:
    Google:
    I'm getting my S7 edge today and would like to use Samsung pay. You don't have to keep NFC on to use it? Sorry if it sounds like a stupid question I'm coming from an iPhone.
    08-27-2016 07:46 AM
  21. TylerLV76's Avatar
    Not a dumb question at all, I wasnt sure till I tried it lol. But no you dont need NFC on as Samsung pay uses a magnetic strip inside the phone to activate the card reader at the store.
    Jamie Wooten likes this.
    08-27-2016 07:48 AM
  22. TylerLV76's Avatar
    danielbroadwell5 -
    One more thing, in wifi>advanced: Network notification is off, hotspot 2.0 is off, keep wifi on during sleep is on, auto connect to At&t is on.
    DEman19901 likes this.
    08-27-2016 07:54 AM
  23. Kelly Kearns's Avatar
    https://uploads.tapatalk-cdn.com/2016...bf57cca035.jpg
    Tap the apps and post the screen showing what apps are using battery please.
    08-27-2016 08:00 AM
  24. Kelly Kearns's Avatar
    And an FYI.. I have been noticing in the Note 7 screenshots that Android System and Android OS has been high on all the screenshots.
    My Note 7 hasn't come in yet so I haven't been able to look at that, but that is on my list to talk to Samsung about. I don't know if there is a good reason for that, but my Android Systems and Android OS always ran very low (single digits) unless there was a problem. There are many Note 7 users with theirs a bit up there that are getting good battery life though.
    08-27-2016 08:26 AM
  25. lammy8's Avatar
    You don't, but it's negligible to leave it on. It uses like 0.5% of your total battery life whilst on/idle. Plus you need it on for any contactless reader, so just keep it on.
    08-27-2016 04:26 PM
69 123
  1. Help!! LG phone locked out by FBI scam. what to do?
    By Katreq in forum LG Optimus Series
    Last Post: 08-25-2017, 06:55 AM
  2. Freaking terrible standbytime! Please help!
    By Mooserman15 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 09-21-2016, 09:32 PM
  3. Curved edges interfere with note taking
    By 2ndHalfCor in forum Samsung Galaxy Note 7
    Last Post: 08-25-2016, 04:55 PM
  4. Help! Blackberry bricked
    By kach474 in forum BlackBerry Priv
    Last Post: 08-25-2016, 10:17 AM
  5. Galaxy S6 Constant Freezes and Reboots. Need Help.
    By fritzo81 in forum Samsung Galaxy S6
    Last Post: 08-24-2016, 10:26 PM
