Originally Posted by
41Pixels My phone did do an update today, wondering if that could have messed something up? AT&T
Sometimes the phone gets all wonky after an update so the best thing to do would be to turn off the phone then simultaneously press on the following buttons: volume UP button > power button > home button until you see blue lettering appear at the top left hand corner. Then once the menu pops up, using the volume DOWN rocker, select the "wipe cache Partition" by using the power button, then the down volume button again to select yes with the power button once more. Once that does its thing, it should automatically be selected on reboot phone so you will just need to press on the power button and voila you will have successfully cleared cache. That usually fixes whatever issue your phone may have
