1. G671's Avatar
    Just wondering if anyone is currently using (and is happy with) any particular battery saving apps on their S7 Edge? In my past experience (with other phones), I've found most of them to be useless. Just want to know if anyone is using anything that has actually shown significant improvement in their battery life.
    08-26-2016 04:20 PM
  2. sicario666's Avatar
    All of them that I've seen are pretty much useless. Best thing to do is either turn off certain features or root your device
    08-26-2016 04:43 PM
  3. optimummind's Avatar
    Greenify works well for me. I use it just for the Aggressive Doze feature. Without root, you can activate it using the adb command. With screen off, I drain 0.9%/hour.
    08-26-2016 07:31 PM
  4. Mike Oz's Avatar
    Can you root an S7 Edge? I havent found one yet.
    11-09-2016 04:48 PM
  5. neil74's Avatar
    Is Greenify (un-rooted) really any improvement over MM doze?
    11-10-2016 03:56 AM
  6. chanchan05's Avatar
    Greenify can make Doze activate in like 10min after setting the device down as opposed to 1hr like default MM. Also, it already has Doze to Go, a feature that will be available on Nougat.
    neil74 likes this.
    11-10-2016 04:47 AM
  1. Weather apps
    By Lefank in forum Huawei Watch
    Last Post: 02-07-2017, 09:56 PM
  2. Why do apps load faster on SnapDragon 652 than on my Note 7?
    By accordex#AC in forum Samsung Galaxy Note 7
    Last Post: 08-29-2016, 09:08 AM
  3. Replies: 1
    Last Post: 08-26-2016, 04:08 PM
  4. What charger for Acer Iconia A1-830
    Last Post: 08-26-2016, 04:07 PM
