1. Antony Guan's Avatar
    I recently started to get these screen overlay error pop-ups when I do certain things to allow permissions. I turned all of them off to see which one was the culprit but now I have no clue where to find that settings page.
    08-26-2016 11:58 PM
  2. Javier P's Avatar
    Take a look here and see if any of the fixes included work for you. Tell us how it goes.
    http://forums.androidcentral.com/sho...d.php?t=657947
    Odd "screen overlay" pop up shows up often with some apps, what is it and how to properly select it?
    08-27-2016 12:19 AM
  3. Antony Guan's Avatar
    Odd "screen overlay" pop up shows up often with some apps, what is it and how to properly select it? - Android Forums at AndroidCentral.com
    I'm just trying to find where I can access the "apps that can draw over the screen" page manually not by some pop up telling me to. It says settings>apps but I couldn't find it.
    08-27-2016 11:55 AM
  4. Antony Guan's Avatar
    Nevermind I found it.
    08-27-2016 12:01 PM
  1. How to do get wifi tether to work on cricket unlimited plan
    Last Post: 10-27-2016, 01:11 PM
  2. speech to text
    By mankidiaz in forum Samsung Galaxy Note 7
    Last Post: 09-01-2016, 03:39 PM
  3. Replies: 3
    Last Post: 08-27-2016, 09:41 AM
  4. How do I reinstal Andoird OS + bootloader?
    Last Post: 08-26-2016, 11:19 PM
  5. Lock Screen Message
    By Phoneguy108 in forum Samsung Galaxy S6 active
    Last Post: 08-26-2016, 10:41 PM
Tags for this Thread
