1. rockitdog23's Avatar
    I just noticed that when I'm on speakerphone on my S7 Edge, nobody can hear me talking. Using the phone like normal works and other voice apps like Voxer work just fine. Anyone seen anything like this? Why would the mic work for some apps and not others? I did a factory data wipe and reset yesterday to see if that would fix the issue but it still persists.
    08-30-2016 09:53 AM
  2. mstrblueskys's Avatar
    They can't hear you at all, or it's hard to hear you?
    08-30-2016 10:36 AM
  3. rockitdog23's Avatar
    They can't hear me at all, like I am on mute.
    08-30-2016 02:01 PM
  4. mstrblueskys's Avatar
    That's strange - that could definitely be a software thing, then. Seems like others are having the issue with no luck. Maybe reach out to Samsung and ask if there's a fix.
    08-30-2016 04:54 PM
  5. rockitdog23's Avatar
    Contacted Samsung and sent it in for warranty repair/ replacement.
    08-31-2016 11:16 AM
  1. Exynos 8890 issue? Bootloop issue, crashing, bricking
    By neil123456 in forum Samsung Galaxy Note 7
    Last Post: 09-03-2016, 05:45 PM
  2. Help with a screen protector and case combo
    Last Post: 08-31-2016, 01:06 PM
  3. A few issues...bluetooth, lightflow, always on...
    By TJohnsonmp01 in forum Samsung Galaxy Note 7
    Last Post: 08-30-2016, 09:45 AM
  4. Replies: 1
    Last Post: 08-30-2016, 07:37 AM
  5. My Samsung E7 has charging issue
    Last Post: 08-30-2016, 01:50 AM
