1. Wizzy's Avatar
    Does anybody know how to calibrate the gyroscope in the S7 edge? It never rotates properly when taking a photo (I have to rotate further to get it to change orientation), and if I open a bubble level app, the bubble is always off-center.
    I've tried a complete factory reset and nothing has changed. If I calibrate within the level app, it only works until I restart the app.
    08-30-2016 10:10 AM
  2. mstrblueskys's Avatar
    Unfortunately, it sounds like you have a hardware issue. .
    Good luck! Report back on how that method works.
    08-30-2016 11:12 AM
  3. Wizzy's Avatar
    I think you're right. I tried the self test and it passed. Unfortunately, there's no option to calibrate. I might need to contact Samsung support.
    This is what I get when I use the level app.
    08-30-2016 11:44 AM
  4. mstrblueskys's Avatar
    Yep - if that's the case and software won't recalibrate, it's probably time to get on the phone or in a chat and see what you can do. Good luck!
    08-30-2016 11:48 AM
  1. Duo Camera not even an option...
    By luke matthews1 in forum HTC One M8
    Last Post: 10-15-2016, 03:16 PM
  2. WhatsApp calls not working anymore
    By leSpring in forum WhatsApp for Android
    Last Post: 09-01-2016, 11:12 AM
  3. why can I not uninstall applock?
    Last Post: 08-30-2016, 12:54 PM
  4. My volte not show in india in Korean phone
    Last Post: 08-30-2016, 10:06 AM
  5. Videos suddenly do not attach to emails - no error message
    Last Post: 08-30-2016, 09:48 AM
