1. Rumblee1's Avatar
    I just received my update but no FM radio. Anyone receive theirs?
    09-01-2016 07:08 PM
  2. hyperx's Avatar
    just download any radio app in google store.
    09-01-2016 07:13 PM
  3. Rumblee1's Avatar
    Ive got tune in radio, but the update was supposed to unlock the FM radio thats built into the S7 & S7 edge.
    09-01-2016 07:52 PM
  4. anon(19981)'s Avatar
    Download next radio and listen to your local fm stations. You do have to have a set of headphones connected to your phone. The radio uses the cord as an antenna.
    MeatLoafT and ToddK like this.
    09-01-2016 08:53 PM
  5. tcdude's Avatar
    Does next radio activate the actual radio and plays it without using data? Or is it just another streaming app?
    09-01-2016 10:29 PM
  6. anon(5719825)'s Avatar
    The Next radio app won't use data since it is getting the signal over the air just as a regular FM radio would. You need to have your headset connected because it uses that as the antenna.
    anon(238680) and ToddK like this.
    09-02-2016 01:38 AM
  7. tcdude's Avatar
    Won't work without a data connection unless I downloaded the wrong app
    09-02-2016 04:53 PM
  8. tcdude's Avatar
    Ok just found right app but it says it's not compatible with this version 😕
    09-02-2016 04:56 PM
  9. anon(19981)'s Avatar
    I downloaded it and it worked fine this morning. https://play.google.com/store/apps/d...oapp.nextradio
    thecomicbookandme likes this.
    09-02-2016 06:01 PM
  10. tcdude's Avatar
    Not available for this device in my region. Why is that? Is it the carrier or the different variants that samsung sends out to different areas?
    09-02-2016 07:09 PM
  11. 1812dave's Avatar
    I am on Verizon in the US. Nextradio works fine. Where are you?
    09-03-2016 09:27 AM
  12. tcdude's Avatar
    I'm in Canada and my carrier is Telus
    09-03-2016 01:35 PM
  13. tanson1011's Avatar
    I'm on bell doesn't work. I downloaded nextradio apk. Got into the app and was able to browse stations but no sound with headphones plugged in. Don't think any of the Canadian carriers unlocked the radio yet.
    09-20-2016 02:14 PM
  14. anon(5719825)'s Avatar
    The app should warn you immediately upon opening if it will work with the phone. If you get a warning, the FM radio is not activated.
    09-20-2016 02:24 PM
  15. tanson1011's Avatar
    I did get a warning at first. Then I got a notification from nextradio. Opened it and it let me in. Set it up and everything.
    09-20-2016 02:27 PM
  1. Replies: 4
    Last Post: 09-03-2016, 10:54 AM
  2. Replies: 1
    Last Post: 09-02-2016, 10:08 PM
  3. What's with the bright flash of light, then nothing?
    Last Post: 09-01-2016, 10:07 PM
  4. Replies: 1
    Last Post: 09-01-2016, 07:06 PM
  5. Changing the way calls are answered android k8
    Last Post: 09-01-2016, 06:52 PM
