1. Murph5150's Avatar
    So there are apps, such as AOD Service, Beacon Manager, DT Ignite, Samsung +, etc that are consuming a lot of memory. Which apps are safe to delete/disable?
    09-02-2016 09:53 AM
  2. jazz70's Avatar
    disable/uninstall DT Ignite first imho and also check after any updates that DT Ignite is not installed or activated again
    DT allows carriers to install bloatware without your permission so it is always first on my list to delete/disable/uninstall
    09-02-2016 10:21 AM
  1. What do you think the battery life will be like?
    By Golfdriver97 in forum Samsung Gear S3
    Last Post: 11-01-2016, 01:57 AM
  2. Going to notice the difference?
    Last Post: 09-05-2016, 04:28 PM
  3. Acer's Z6 Plus with a massive battery!!
    By Golfdriver97 in forum Acer Android Phones
    Last Post: 09-02-2016, 09:47 AM
  4. Numbers to Letters on new Pin-Pad layout - S6
    Last Post: 09-02-2016, 09:26 AM
  5. Can you remove Samsung galaxy S7 Edge battery?
    Last Post: 09-02-2016, 09:18 AM
