1. Dylan Bonvissuto's Avatar
    I've had my s7 edge for about 3 months now, the charging has always been fine. Now out of the blue the fast charging doesn't work I have tried everything from switching cable's, changing chargers completely, reseting the phone, making sure the fast charge is enabled, even cleaning the USB charge port. The other day my phone did over heat quite bad to the point that I was not even able to touch my phone. Does anyone have any ideas what the problem could possibly be any help would be appreciated! Thanks in advanced
    09-02-2016 08:37 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Any problems with data transfer via USB? I'd wonder about some problem with the actual microUSB port. Any water exposure?
    You may just have to contact Samsung for warranty repair. Try your carrier first, to see if they're willing to replace your phone, even after 3 mo.
    09-02-2016 10:42 PM
  3. amerfreedom's Avatar
    I updated on Verizon for my Galaxy S7 tonight and my fast charging stopped working. Was told by Verizon it was due to the software update and that Samsung was working on a patch. Not sure if that is the same issue you've encountered.
    B. Diddy likes this.
    09-07-2016 01:43 AM
  4. steezytech's Avatar
    settings>battery scroll down to the botom and thereis a tickboc that says fast charging. maybe its just turned off. maybe you did it accidentaly or if you have kids maybe one of them did it accidentally idk
    09-07-2016 07:24 AM
  1. Just switched from iPhone to Galaxy S7
    By JBly in forum Samsung Galaxy S7
    Last Post: 09-06-2016, 04:52 PM
  2. Note 7 battery issue...maybe issues with S7 Edge and S7?
    By OUGrad05 in forum Samsung Galaxy S7 edge
    Last Post: 09-05-2016, 08:51 AM
  3. Samsung 4 phone and battery is draining fast.
    Last Post: 09-03-2016, 05:12 AM
  4. How do up upload my pics from galaxy S7 to my laptop
    Last Post: 09-02-2016, 08:28 PM
  5. USB port stopped working?
    Last Post: 09-02-2016, 08:26 PM
