1. andrewsamsung's Avatar
    Hi there i purchased a samsung S7 edge and after about two months the screen started to flicker and turn green ( sometimes it went completely black) on the back of the phone there is a crack which happened after i walked into a table with the phone in my pocket even after this crack the phone worked fine for about a month . i sent the phone back to base (the belgian phone company where i bought the phone) they took a look at it and told me it will cost 433 euro to repair the phone, they said the problem was the crack on the back. Can anyone tell me if a crack at the back of the phone can cause the front screen to not work and if so 433 euro seems very steep for a back screen replacement?
    09-03-2016 06:47 AM
  2. hyperx's Avatar
    1. did you try to factory reset your phone?
    2. see if you can buy warranty from samsung dot com - it will cover your front screen(2 times), but you have to read their terms about back cover it may cover this too.
    it will be cheaper than 433 euros, around 230...
    09-03-2016 07:19 AM
  3. andrewsamsung's Avatar
    thank you
    09-23-2016 04:05 AM
  1. Is there any 6.0 custom rom for infinix hot 3?
    By abula112 in forum Ask a Question
    Last Post: 10-29-2016, 07:40 PM
  2. Skinomi Screen Protectors...
    By billykac in forum Samsung Gear Fit 1 & 2
    Last Post: 09-15-2016, 10:21 AM
  3. Samsung Dubai Recall Thread
    By Snappy Phoenix in forum Samsung Galaxy Note 7
    Last Post: 09-05-2016, 03:39 PM
  4. Replies: 24
    Last Post: 09-03-2016, 05:25 PM
  5. How do I unlock the screen overlay from setting?
    Last Post: 09-03-2016, 06:39 AM
