1. Rumblee1's Avatar
    Every once in a while, my S7 edge will loose its data connection. This happened so frequently with my first one that I turned it back in for my 2nd. Both phones were brand new,never used. My 2nd one doesn't do it as much any more, but ive got to check it after taking it off the charger every morning and nake sure its connected. This morning it wasn't. Or it'll be perfectly fine, but after leaving my home for a while, I'll notice no messages or calls coming through so I'll check and, again, the data connection is off. A simple reboot does the trick. But this is odd. Even the Verizon techs are stumped. After swapping out the first phone and it was still happening on the 2nd, they had me do a factory reset, then sent a new sim and another factory reset. It is much better. Now its only happening once or twice a week. I have no Tasker type apps set up. If anyone else had a similar issue or an idea what could be causing this, im open for suggestions. One more thing. Its only the data connection that goes out not wifi or anything else
    09-04-2016 06:17 AM
  2. naturalguy#AC's Avatar
    I had the same issue. I finally figured out that it was wifi calling causing this. For whatever reason when I had wifi calling enabled the data connection would turn off. Since I have disabled it I have not lost data connection
    09-04-2016 07:48 AM
  3. Rumblee1's Avatar
    Ok, im going to try it. Thanks.
    09-04-2016 10:15 AM
  4. Rumblee1's Avatar
    Ok, went to turn off wifi calling, but it wasn't enabled. So im back to square 1.
    09-04-2016 10:17 AM
  5. t11rmh's Avatar
    If it happens on more than one phone then maybe try a new sim card as that is a constant.
    09-04-2016 01:31 PM
  6. naturalguy#AC's Avatar
    Sorry man, hope you get it figured out
    09-04-2016 02:19 PM
  7. koves's Avatar
    Ya definitely try a new sim card
    09-04-2016 02:24 PM
  8. Rumblee1's Avatar
    On 2nd one.
    09-04-2016 03:29 PM
  1. Replies: 3
    Last Post: 04-19-2018, 04:05 AM
  2. Zack from JerryRig explains why the Note7 battery may explode.
    By D13H4RD2L1V3 in forum Samsung Galaxy Note 7
    Last Post: 09-07-2016, 07:51 AM
  3. Why are we facing screen ovalay error message on our phones
    By Davidmonster7739065549 in forum Ask a Question
    Last Post: 09-04-2016, 08:05 AM
  4. Why does my note 3 say charging paused battery temp to low
    Last Post: 09-04-2016, 05:29 AM
  5. Replies: 0
    Last Post: 09-04-2016, 03:16 AM
