Some years ago I moved from a BlackBerry to a Nexus - I pretty much had no issues of substance and when I had questions, everything was fairly straightforward. Now, moving from a Nexus to a carrier S7 Edge, there are a lot of (mostly little) things that are confusing me. Your experience insights appreciated. :-D
The choice of carrier vs unlocked was not mine, so I have to deal with that. It does come with a few specific questions though:
1) The T-Mobile app, the one you can't disable (along w/ the 'Mobile Hotspot' app) - you cannot remove permissions (Locations, Phone, and SMS) from it or force stop it. Specifically you can remove the permissions but they come back fairly immediately. What does it do? It seems to accumulate app data. When you open it, and uncheck 'Agree', it just lets you close it. I'd have presumed at that point it shouldn't do anything but it clearly still does.
2) To confirm, the other T-Mobile apps (TV, Visual Voicemail, etc.) still say 'Force Stop' is available even when disabled. On my Nexus devices it was clear there was nothing running but the implication here is they are in some form running even if disabled? I think I'm not understanding that correctly so just trying to confirm.
In terms of Samsung components, and getting used to TouchWiz, I have a few specific questions:
3a) Updating Samsung apps from the 'Galaxy Apps' seems not to be complete - a number of things seem to have upgrade options only within the 'About' section of those individual things. Is there a list of what can / needs updating outside of the regular 'Galaxy Apps' process? For example, the Samsung keyboard required upgrade within the settings.
3b) Likewise, some of the Samsung apps (Beaming Service for Samsung, Samsung Internet for Android) don't appear to update through Play Store automatically either. If I hadn't coincidently scrolled down in 'All' apps, I wouldn't have seen there were updates. Any known reason for that?
4) S Beam prompted it was ready but I don't see what that's used? Is there an app that needs to be installed to configure it? I turned off Android Beam but that seems to be different than S Beam. I'm a bit confused on this.
5) I can't quite figure out how to use S Voice or if I should be - given I use the 'OK Google' just fine. Just a general question as to how and why people use it or if I should go ahead and disable it. The Android Central article on it is nice but those are things I do through Google fine. Just want to make sure I'm not missing something?
Thanks much for reading this far, pardon the verbosity but figure details helped me answer questions back at CrackBerry forums.
Cheers.
Cheers.
