1. Abby Normal's Avatar
    I just got a notice of a system update.....
    A quick look around here and I don't see any info on it.......
    Of course some times I can't find my car keys too ...LOL
    Anyone know anything a new system update, mine just appeared this morning.....
    Thanks in advance
    09-07-2016 09:55 AM
  2. Golfdriver97's Avatar
    How big is it? It may be a monthly security update.
    09-07-2016 09:59 AM
  3. gjh1978's Avatar
    Are you on the international or US carrier version?
    09-07-2016 10:01 AM
  4. gjh1978's Avatar
    AT&T version says I'm up to date...got the August security update about 10 days ago...
    09-07-2016 10:05 AM
  5. Abby Normal's Avatar
    US ,,,,,, Verizon.
    09-07-2016 10:05 AM
  6. gjh1978's Avatar
    Well, screenshots please! If it's something new!
    09-07-2016 10:07 AM
  7. tshirttan408's Avatar
    yeah I've got one, 296mb says it improves bluetooth, nfc as well as adding samsung cloud. hopefully it sorts out my phone radio/wifi battery drain as well.
    09-07-2016 10:18 AM
  8. Bichon-Fan's Avatar
    Looks like the release notes are up on the VZW site for the new software, MMB29M.G935VVRU2APG5: Samsung Galaxy S7 edge Software Update | Verizon Wireless
    09-07-2016 10:23 AM
  9. Abby Normal's Avatar
    OK this is wierd... I rebooted and it didn't reappear ..
    09-07-2016 10:29 AM
  10. Abby Normal's Avatar
    Correction,,, it is now on the screen and saying SOFTWARE update.
    containing enhancements and improvements to the Samsung Galaxy S7 Edge including Android security updates.
    Software Version MMB29.G935VVRU2APG5
    HD voice improvements. new Galaxy features, such as support for NextRadio and Barcode Beaming for UPC codes
    Listen to live FM radio on your phone. You will be able to see hear and react to local radio programs on the Edge.
    NextRadio is supposed to use less battery than others...........
    Guess that's about it..........can't see anywhere for what the size is.....
    09-07-2016 10:37 AM
  11. Bleezy's Avatar
    09-07-2016 11:26 AM
  12. underway99's Avatar
    I got it yesterday, but haven't seen any changes. The phone overheated a few times while doing the update, though. First time I've seen this phone go into cooling mode.
    09-07-2016 11:27 AM
  13. scorpiodsu's Avatar
    Looks like a got this update 2 days ago.
    09-07-2016 12:24 PM
  14. scorpiodsu's Avatar
    Verizon removes (hides) Samsung cloud on the note 7 so I'm sure they do the same for the edge. They want people to use their cloud service which is highly inadequate.
    09-07-2016 02:53 PM
  15. mmcclure0453's Avatar
    That's the update I received on 9/1 that heated my phone and had it acting up for a while. Battery drain was horrible for a little less than a day. After that and a restart, it settled down and has been fine since.
    09-07-2016 07:21 PM
  16. Frenzytom's Avatar
    When I got my phone a few days ago, there were 3 updates in a row on the phone. The phone heated up pretty good but now it is as cool as a cucumber. VZW version here.
    09-07-2016 08:51 PM
  17. Kyprain's Avatar
    Once I updated the phone it will not charge from my car charger. My wife has same phone and she didn't update and can charge. Once I plug in my phone it says moisture detected.
    09-09-2016 10:43 PM
  1. Can The FM Activation In the S7 Be Used To Transmit?
    Last Post: 09-07-2016, 11:18 AM
  2. Latest Twitter update causing crashes?
    Last Post: 09-07-2016, 10:45 AM
  3. My Files icon not showing on apps screen of galaxy s7
    Last Post: 09-07-2016, 10:00 AM
  4. How do I delete my sent and recieved file on my galaxy s7
    Last Post: 09-07-2016, 09:54 AM
