Early yesterday my S7 edge started having pretty epic keyboard unresponsiveness - not lag, just not allowing any input for a while. I started down the chain of things recommended that included the touch screen test ("*#0*#"), wipe cache, reset(s), ..
I was already using the Google Keyboard but I tried the Samsung Keyboard and same problem between the two.
So yesterday evening went and swapped the phone, it's only a few days old and with a bit of debate they took care of it.
Some hours into today and the problem is back. I proceeded to back out change after change, packages installed, the minimal things I disabled via Package Disabler, etc. No joy.
I turned off power saving entirely because of the various 'CPU scaling' threads - no joy.
THEN I started noticing it starts effecting the same general region of the screen - toward the bottom 'row' in the launcher and elsewhere. The problem 'creeps' so-to-speak after I start having it in the keyboard BUT only after I've used the keyboard feature once. So if I do a reset, back in, everything is fine on the dialer, launcher, etc. until AFTER I use the keyboard once. Which includes the initial boot unlock keypad.
The last bit of detail is that anytime the keyboard is open 'Select Keyboard' is in the notification tray - I see this here http://forums.androidcentral.com/samsung-galaxy-s6/512615-select-keyboard-input-notification.html but I disagree it's an 'Android bug' as I don't see it on any other Android device. So is that a Galaxy / TouchWiz thing or is that potentially a symptom of another problem?
Thank you for reading this far.
