1. wrathofcon's Avatar
    Hello!
    I am trying to set up my new s7 egde to unlock with my fingerprint (I've added my prints, selected the fingerprint to unlock option) but when I go to unlock my phone, I just swipe up and it takes me to my home screen, and when I place my fingerprint on the sensor nothing happens. Any advice? I've looked up a few setup guides and I think I've followed all their instructions.
    Thanks!
    09-07-2016 05:46 PM
  2. MeatLoafT's Avatar
    Check your smart lock settings, you may be in your "unlocked" location. Also check the lock timeout, I have mine set to immediate, you may just not be waiting long enough if it's set differently. Btw, on your start screen where you swipe, you've got your 2 quick app icons, in the center there should be a lock icon. If you touch it, it should move down and lock the device. Good luck!
    09-08-2016 12:25 AM
  1. Replies: 1
    Last Post: 09-07-2016, 05:46 PM
  2. Where do I find my clipboard on samsung galaxy prime
    Last Post: 09-07-2016, 05:36 PM
  3. Replies: 0
    Last Post: 09-07-2016, 05:18 PM
  4. Emails won't sync on my phone..
  5. why can't i download any Apps on my Lg stylo or updates
    Last Post: 09-07-2016, 04:51 PM
