1. Snewz's Avatar
    NOTICE: This is a legitimate question as I am concerned.
    When charging my s7 edge with fast charging, it always gets got even without a case and sitting completely in the open thus getting ventilation.
    My question is whether or not it is okay to, while fast charging or when it starts to get hot, put it in a fridge to cool down. This would be putting the hot phone to cool fast in a fridge. I just want to know if it's safe.
    ____________________________
    Also a quick side question, the port for charging my phone [the port on the phone itself] is always able to be wiggled while it's plugged in. With past phones the charging port while the cord was plugged in was always stiff and I'm wondering if the s7 edge's charging port should be able to be wiggled or stiff.
    Quick clarification, I mean the cord while plugged into the port is wiggly and the port that you plug into is right and proper stiff as it should be. It's not like that's broken.
    Thanks for all the help and kudos is you read this far!
    09-09-2016 02:36 AM
  2. chanchan05's Avatar
    I won't put it in the fridge. It's made of glass. It may get more brittle with too rapid cooling after getting hot.
    Snewz likes this.
    09-09-2016 03:00 AM
  3. Snewz's Avatar
    I never thought of that. Thanks! That's settles that, but how about my second question? That's all I have left.
    09-09-2016 04:14 AM
  4. chanchan05's Avatar
    If it's getting hot, just don't use the fast charging. Since the fast charging only works until 60%, if you're charging close to that it won't make much of a difference. In my experience, charging from 20% to a 100 is up to 30min faster on fast charging, but when charging by from between 40-50% to full, it's only 15min faster, so no big deal for me since I usually charge before battery hits 40%.
    The cord isn't something I'd worry about if it's working properly.
    MetalKore likes this.
    09-09-2016 06:25 AM
  5. PJesse's Avatar
    I agree, you also have to remember that when you pull it out of the fridge, water vapor in the air will condense, and because water molecules are smaller than air molecules, water could condense on your phones internals, and fry your phone. So much for good intentions.
    09-09-2016 07:04 AM
  1. Samsung Wireless FAST charging pad
    By Cappaccinodagreat in forum Chargers and Batteries
    Last Post: 09-09-2016, 04:16 PM
  2. Replies: 2
    Last Post: 09-09-2016, 03:26 AM
  3. I have a S6 and i cant use any of my apps.
    Last Post: 09-09-2016, 03:05 AM
  4. Replies: 0
    Last Post: 09-08-2016, 08:59 PM
