1. thunderbomb's Avatar
    I currently have the Zagg HD one on my phone. I was using a Otterbox Symmetry case and every time I'd put the phone back into the case it would peel up and soon after bubble up. I've had it replaced a few times and switched to the Otterbox Commuter case and it still does it. Does anyone have a good solution for a case friendly screen protector? I know the Zagg curved glass isn't available yet according to their website. Thanks in advance.
    09-10-2016 10:11 PM
  2. danielbroadwell5's Avatar
    I had the same issue you did. I just removed the screen protector all together and don't use one.
    09-10-2016 10:16 PM
  3. thunderbomb's Avatar
    I was gonna do the same but I'm afraid of the screen cracking. Some days I wished I kept my S6 edge plus.
    09-10-2016 10:18 PM
  4. thorgrim's Avatar
    Could just get the Otterbox Defender, has built in screen protector. I found that the best after trying various other cases and screen protector combos.
    09-10-2016 10:55 PM
  5. mmcclure0453's Avatar
    I wanted this to be the answer for me too. I ordered the Defender and took the built in screen protector out of the case after 2 days of use. The screen sensitivity for me was greatly reduced. Screen clarity was reduced also. Outside edges of the keyboard were almost useless.
    I removed the built in protector and am using a Skinomi protector on it now with the case. No more sensitivity issues. The phone is a little loose in the case but it's not bad. All buttons work fine.
    Hated to remove the built in protector but I had to have my phone work correctly.
    09-10-2016 11:39 PM
  1. Wasted screen space
    By nnthemperor in forum Nexus 6P
    Last Post: 09-11-2016, 08:22 AM
  2. screen overlay
    By Rkolo1419 in forum Samsung Galaxy Note 5
    Last Post: 09-10-2016, 10:07 PM
  3. Replies: 1
    Last Post: 09-10-2016, 07:28 PM
  4. Replies: 0
    Last Post: 09-10-2016, 06:17 PM
  5. simple reminder servic on home screen
    Last Post: 09-10-2016, 05:24 PM
