1. John Deergab's Avatar
    I searched every tutorial for my S7 Edge and I can't seem to rotate my web-browser. Yes, I have pulled down, auto-rotate, restart, and it's not rotating even did the same on lock screen including restart nope no rotations. This is also been rebooted twice still like it was mentioned from a previous tutorials on here and other sources. NOTHING IS WORKING FOR ME!
    09-11-2016 05:49 PM
  2. robber's Avatar
    Search the app store, there is an app that will force a rotate which will regain functionality. I was even able to uninstall the app afterwards and everything worked. Sorry, but I can't remember the app name.
    09-11-2016 06:11 PM
  3. robber's Avatar
    Rotation lock adaptive is the name. Good luck.
    09-11-2016 06:14 PM
  4. DeMonSpencer's Avatar
    Thanks. I'll try that because this problem is annoying.
    12-15-2016 02:31 AM
  5. James Butler5's Avatar
    On your drop down screen look for a setting called portrait. Clicking it should change it to Auto rotate.
    12-17-2016 07:38 PM
  1. S7 edge heating up with gear VR 2
    By note7s7edge in forum Samsung Galaxy S7 edge
    Last Post: 09-13-2016, 12:51 AM
  2. Tried to unlock - now all apps stopped working
    By esterina17 in forum Samsung Galaxy S5
    Last Post: 09-12-2016, 01:19 PM
  3. Samsung Galaxy S7 Problems with Apps and Boot After Rooting
    By MacAndSwiss in forum Samsung Galaxy S7
    Last Post: 09-12-2016, 07:07 AM
  4. Replies: 0
    Last Post: 09-11-2016, 04:33 PM
