1. Stwutter's Avatar
    For the last week or so, my Android System usage has been higher than SOT. Often 30-40%, whereas it used to be 10-15 max. I used to get 16-20hrs easily, with 4-6hrs SORT and quite a bit left. Now, I'm using 7-10%PH, and I'm lucky to get 2.5hrs SOT.
    I've been posting on here, and have disabled just about everything possible, installed Greenify (unrooted-i don't really want to root my phone as I use Sky Go and 2 banking apps, and I know these will likely break), done 3 resets, cleared the cache and the partition cache numerous times... The same.
    I think I got an update 7-10 ago (I'm on O2 in the UK) so I wondering if this may be the reason...
    Has anyone else encountered anything similar after this or other recent updates? I thought I'd post this as a last resort - I'm considering flashing the the stock S7 Edge firmware otherwise to see if that helps.
    Cheers.
    09-12-2016 02:56 AM
  2. chanchan05's Avatar
    I got the same with the last update. Checking under the stock battery stats, Android system is huge. However under GSAM, the battery drain falls under Samsung Cloud. You could turn that off instead.
    pjwk81 and Stwutter like this.
    09-12-2016 03:31 AM
  3. Stwutter's Avatar
    Cheers. did it work for you?
    I have gsam also, but it didn't show on mine - are you rooted?
    09-12-2016 04:49 AM
  4. chanchan05's Avatar
    Nope. Well It seems to have died down and battery consumption is normalizing now that Samsung Cloud has backed up like that 1GB of data.
    Stwutter likes this.
    09-12-2016 04:53 AM
  5. Alanhd's Avatar
    Did you try clear the system cache after the update.
    09-12-2016 04:59 AM
  6. Stwutter's Avatar
    OK. I had only about 70mb on Samsung Cloud, but I've turned it off to see if it makes any difference.
    09-12-2016 05:03 AM
  7. Stwutter's Avatar
    Yes. I mentioned in the OP that I'd cleared both the system and app cache on more than one occasion.
    09-12-2016 05:04 AM
  8. Alanhd's Avatar
    That will teach me to no skim.
    Stwutter and chanchan05 like this.
    09-12-2016 08:47 AM
  9. lammy8's Avatar
    Worth sharing a screenshot to show what's draining it.
    If it's mediaserver causing the drain then the current workaround is to disable chrome as there's a bug in it. I'm using chrome beta for now and having no draining issues
    09-12-2016 11:53 AM
  10. Stwutter's Avatar
    It's not media server - it's Android System. Also, Chrome shows up on gsam for me, but never unusually high.
    09-12-2016 12:19 PM
  11. jweaver57's Avatar
    I recieved an update about then in the US and ever since then my phone will drain in 15 mins just scrolling facebook or the internet at least 7 percent. In 15 mins.....
    09-12-2016 12:49 PM
  12. Stwutter's Avatar
    As an update, got nowhere with this, so convinced myself it was the update. So decided to flash an older firmware (Vietnamese from May, I think..) last night.
    So far today, 9hrs off the charger and down to 61%, with 2hrs SOT - far, far better. Also, SOT is about 6% higher than Android System, whereas it had been double the SOT for the past 2 weeks. I think AS is still a little high, but this may be as I only flashed last night so there's still some stuff going on in the background.
    Not the ideal solution, but having done numerous resets, cache wipes and disabling a £700 phone to the extent that it was just useful for the odd call, it worked for me - and, finally, I have a build that gives me the Yahoo Edge sports scores. Why this isn't on the UK version confuses...
    09-14-2016 09:19 AM
  13. lammy8's Avatar
    Could still use a screenshot to see what you mean
    09-15-2016 04:45 PM
  1. LG G5 & battery
    By winsebsea in forum LG G5
    Last Post: 09-18-2016, 05:57 PM
  2. Yellow battery graph?
    By z06mike in forum Samsung Galaxy S7 edge
    Last Post: 09-15-2016, 03:08 PM
  3. Replies: 7
    Last Post: 09-12-2016, 01:56 PM
  4. Galaxy S7 Bluetooth ruined by AT&T update to 6.0.1
    By KingDingbat in forum Samsung Galaxy S7
    Last Post: 09-12-2016, 01:33 AM
  5. Galaxy S7 Bluetooth ruined by AT&T update to 6.0.1
    By KingDingbat in forum Android 6.0 Marshmallow
    Last Post: 09-12-2016, 01:09 AM
