1. bandofbrothers2112's Avatar
    Hello.
    Does anyone know if my s7 edge will charge ok on a wireless charging pad for the s6 ?
    09-12-2016 03:02 PM
  2. SpookDroid's Avatar
    09-12-2016 03:18 PM
  3. scorpiodsu's Avatar
    Hello.
    I don't think there are pads specifically for the phones. The s6 and s7 use the same technology and therefore can use the same charger. Not possible for a manufacturer to make a charger that only works with one of the phones when they use the same tech.
    bandofbrothers2112 likes this.
    09-12-2016 03:46 PM
  4. stang6790's Avatar
    It will work fine but they do make the fast wireless charger now that would charge it faster.
    09-12-2016 05:31 PM
  5. bandofbrothers2112's Avatar
    Cheers Guys.
    I've turned off Fast Charging on my s7 edge anyway so the 'fast charging' spec isn't a deal breaker.
    The s7 wireless charger in the uk is £40 and I can pick up a s6 option for £20 which is the reason for my query.
    09-12-2016 11:11 PM
  6. SpookDroid's Avatar
    Cheers Guys.
    Just remember that a 'Fast' Wireless charger has nothing to do with your phone's Fast Charging mode (that only works with compatible wired ones). The fast wireless is just a faster standard that charges, well, faster than the older ones, but it's still not 'Fast Charging'. In fact, the 'fast' wireless chargers are about as fast as a 'normal', non-Fast-Charging 2A wall adapter. You can read a bit more about that here:
    Wireless Fast Charging explained | Android Central
    09-13-2016 11:17 AM
  7. bandofbrothers2112's Avatar
    Well the Samsung Wireless Charging Pad meant for the s6 charges my s7 edge just fine.
    Alls good.
    SpookDroid likes this.
    09-13-2016 11:21 AM
  1. Nexus 6P performance/lagginess question
    By jayjay234 in forum Nexus 6P
    Last Post: 09-12-2016, 06:14 PM
  2. Odd charging problem
    Last Post: 09-12-2016, 02:51 PM
  3. Real vs Fake Fast Wireless Charger
    By IMBA666666 in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 09-12-2016, 11:40 AM
