01-09-2017 10:29 AM
94 1234
tools
  1. ScottsoNJ's Avatar
    Try Package Disabler Pro. It will freeze all your bloatware. It works great and no rooting is needed. I think it costs $ 1.49
    KPMcClave likes this.
    09-30-2016 07:35 AM
  2. PecanPie117's Avatar
    Hello all
    New to the forum. I have had this issue myself and I have read on plenty of android sites that in the last few days a lot of s7 users are having major battery issues.
    I found the cause to be the "oculus and Samsung VR" apps, once removed my phone stopped overheating and battery returned to normal.
    I also rebooted my phone, held power+home+volume up and noticed an update actually failed, and reinstalled the update.
    09-30-2016 08:35 AM
  3. KPMcClave's Avatar
    It must be more than occulus as it's happening on phones without it.
    Gear VR.
    09-30-2016 11:50 AM
  4. KPMcClave's Avatar
    I absolutely agree with this recommendation.
    09-30-2016 11:51 AM
  5. KPMcClave's Avatar
    Hello all
    That "update failed" screen shows everytime I try to access the recovery menu. It seems to be bogus and recovery eventually appears.
    09-30-2016 11:52 AM
  6. hishaq96's Avatar
    How do you use the package disabler and what do you have to disable to get better battery life
    09-30-2016 12:18 PM
  7. ScottsoNJ's Avatar
    Well it disables all your bloatware so its not running in the background
    I guess its sort of like Greenafy.
    09-30-2016 12:38 PM
  8. hishaq96's Avatar
    Is package disabler pro and greenify the same and which is better to get good battery life?
    09-30-2016 01:05 PM
  9. Leykis's Avatar
    Started having battery issues on Wednesday morning. When I left the house my phone was at 100% and when I used the phone on break 2 hrs later it was at 15% and hot. All of that and the screen was never on. Even connecting it to a charger the phone would continue to drain while on. I had to power it down for it to charge. Deleted all the Oculus VR apps and it seems to have fixed the issue. I'm guessing a new update did something because I've had the Oculus apps on my phone for several months now and never had an issue with battery drain.
    09-30-2016 05:56 PM
  10. ThePoisonBerry's Avatar
    Ok I'll give it a try. Having same issues
    09-30-2016 07:24 PM
  11. mundo472's Avatar
    Deleted gear Vr and it got a little better, but Android system and OS still double each, what the screen is using. Also I keep getting the "not connected to network" message sporadically so there is CLEARLY a problem with the radio file. C'mon Google...did BlackBerry and Verizon suddenly take over your software division? (Sorry..reminds me if the random reset debacle if the Verizon Z10)
    09-30-2016 10:22 PM
  12. hishaq96's Avatar
    Hello I just wanted to know by using the package disabler app does it improve battery life and the android system drain.
    10-03-2016 08:13 AM
  13. Golfdriver97's Avatar
    Can you show us some screenshots of your battery drain? Did this recently start?
    10-03-2016 09:22 AM
  14. ecfritts's Avatar
    I have it installed on my S7E. I tried to disable bloat on my phone but had no idea what most of the things were and if I should disable them (or if it would cripple my phone if I did). I read a thread on here saying it was a good app and would help, so I bought the app. Not sure if improves my battery life but I'm sure it can't hurt.
    10-03-2016 09:23 AM
  15. hishaq96's Avatar
    S7 edge battery draining fast-1475504893141.jpgS7 edge battery draining fast-1475504897992.jpg
    Today's battery
    10-03-2016 09:28 AM
  16. Golfdriver97's Avatar
ID:	241262Click image for larger version.
    Today's battery
    Thanks.
    Does your phone sit idle a lot?
    10-03-2016 09:30 AM
  17. Golfdriver97's Avatar
    I think if you avoided those that aren't listed in the App Drawer, anything you disable should be fine.
    10-03-2016 09:32 AM
  18. hishaq96's Avatar
    Thanks.
    Yes sometimes but not for long. My battery had been draining regularly. This was yesterday's S7 edge battery draining fast-1475507288501.jpgS7 edge battery draining fast-1475507296390.jpg
    10-03-2016 10:08 AM
  19. hishaq96's Avatar
    Yes sometimes but not for long. My battery had been draining regularly. This was yesterday's Click image for larger version.
ID:	241273Click image for larger version.
    Do you think using the package disabler app will give me a better battery?
    10-03-2016 10:09 AM
  20. Golfdriver97's Avatar
    I really don't think it's as bad as you think. As the phone sits, it's going to drain some. If you are seeing about a half a percentage point per hour, that's really good. Also, as the device sits, something is going to account for battery use. That is where the OS will be closer to the top. Once you start playing a game, all those stats will change.
    10-03-2016 04:33 PM
  21. hishaq96's Avatar
    This much quick battery lost has not happened before. What is the problem and why is systemui draining battery It hasn't happened in the past.
    10-05-2016 07:22 AM
  22. B. Diddy's Avatar
    Could this be related to the Oculus battery drain issue? Have you installed the most recent Oculus update that was supposed to fix it? Or you could also try disabling Oculus temporarily.
    10-05-2016 11:22 AM
  23. hishaq96's Avatar
    Thanks I received the new Oculus update this morning and have updated it but this has happened from nowhere.
    10-05-2016 11:43 AM
  24. B. Diddy's Avatar
    Have you done the usual troubleshooting steps like wiping the cache partition or booting into Safe Mode?
    10-05-2016 11:48 AM
  25. hishaq96's Avatar
    I cleared the cache partition last night as I wasn't getting as good battery life before this.
    10-05-2016 11:57 AM
94 1234
  1. Snapchat flash to fast or quick
    Last Post: 09-02-2017, 08:56 AM
  2. Galaxy S6 Edge - Recent Apps button self pressing
    Last Post: 09-02-2017, 04:51 AM
  3. GSam Battery Monitor
    By bat1939_KM in forum Moto Z Force
    Last Post: 09-15-2016, 08:35 PM
  4. Replies: 1
    Last Post: 09-15-2016, 04:23 PM
  5. Replies: 0
    Last Post: 09-15-2016, 02:28 PM
